Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby dieselhead123 » Tue Jul 17, 2012 8:26 pm
Good work on those rocker covers mate, you have the best ones for the Transit, where the oil filler is at the front end of the cover, another thing to bear in mind when fitting the Essex into a Transit.
Postby robbie.cee » Tue Jul 17, 2012 9:26 pm
just been doing some research... camshaft pushes in from front. the bearings presumably or shells will have oil grooves?
also been prevented from fitting block to stand due to short bolts.... just seen an essex on a nigh on identical stand but bolted on from side using an engine mount !
result i can start work! need that oil pump and water pump some time soon!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Tue Jul 17, 2012 9:36 pm
I will get some pump prices in the morning mate,
Postby Eggski » Tue Jul 17, 2012 9:56 pm
Nice work, you want mine dropping off weekend?!! :lol:
Custom Trend 2.2 125/290s 64reg (2014) DCIV. (Remapped by Vantuner)
Mk7 2.4 115T350, 57reg (2008) crewcab tipper in Saffron yellow. (De EGR'd and tweeked by Vantuner)
Mk5 2.5 banana, 76ps, V reg (2000) 190 crewcab tipper. (sold but not forgotten)
Eggski
Postby robbie.cee » Tue Jul 17, 2012 10:34 pm
Greg m8 your always welcome! your doors await you sir! :lol:
Had
MAKE IT FIT
robbie.cee
Postby Eggski » Thu Jul 19, 2012 7:44 pm
:D
Eggski
Postby transitandy » Thu Jul 19, 2012 8:20 pm
Very nice work :)
Postby robbie.cee » Wed Jul 25, 2012 8:35 pm
well been making use of this paid paternity ...
can anyone confirm where dots point on the two wheels pls as mine arent meeting!
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Wed Jul 25, 2012 8:49 pm
Ha :lol: wonder if i crank it round if theyll meet i bet #1 is at tdc in bang not suck or sommit!!! ill investigate now!
this is helpful
http://www.marcos-restoration.net/downl ... ebuild.pdf
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Wed Jul 25, 2012 9:31 pm
yeah what a tit was 180degree out! :lol:
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Wed Jul 25, 2012 10:52 pm
Hows that timing gear, no damage of any kind, little chips in the nylon etc.
Postby robbie.cee » Wed Jul 25, 2012 10:57 pm
looks sweet as but dont trust it. steel quaife one double price of fibre replacement but worth the extra 70 quid i reckon. noisy tho!
should have seen the state(s) of the oil :shock:
coolant and oil and mud lol
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Wed Jul 25, 2012 11:08 pm
Still got that black enamel if you want it :wink:
Postby robbie.cee » Wed Jul 25, 2012 11:12 pm
got a spray enamel today and 5l degreaser, made a sort of parts washer out of some old grey plastic boxes and got a drill powered pump if needed too 8)
cheers any ways Al.
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Wed Jul 25, 2012 11:13 pm
:wink:
