My MK5 Minibus Project
Re: My MK5 Minibus Project
Postby dieselhead123 » Fri Mar 22, 2013 12:10 am
vanmanloki wrote:
dieselhead123 wrote:Hi mate, looks like you need a new rear floor panel there.
These are still available and are galvanised, exactly what Ford should have done with the whole van!
Hi Tim, i had thought about getting a new floor panel, are they expensive?
Hi there, sorry :oops: managed to post this in Ron's thread :oops:
Anyway, new floors are available, £96 plus £12 delivery, go forward to the rear of the sld opening.
Once the floor is removed, any necessary repairs to rear spring hangers and chassis rails will be a lot easier.
Postby RonTransitmk5 » Sat Mar 23, 2013 12:00 am
RonTransitmk5 wrote:
robbie.cee wrote:coffee ere sat mornin early ish>?? you cut my bulkhead ill fix window! :wink:
Great :idea: :wink:
However not sure if I can do Sat am as may have some work to do 7-noon, won't know til tommorrow evening :(
Will update tommorrow night :)
Can't make Saturday as working all day, sorry will hook up another day
2003 Ford Transit Connect 1.8 TDDI Red.
1999 V reg MK5 Bus(M2) Mid Roof, 2.5di, diamond white. GONE
RonTransitmk5
Postby vanmanloki » Sat Mar 23, 2013 10:02 pm
vanmanloki wrote:you were right about that sound deadening, the more i took off the more rust and holes i found, it took me 6 hours but got it all off :)
Is that all, must have missed some lol
i know, felt like it took longer. but to be fair, i did do a few patches the day before :) but on that day i was at it for 6 hrs non stop my back and knees were killing me :?
FORD BUILT TOUGH
1998 Tourneo GLX restoration
viewtopic.php?f=27&t=122620
How to remove a rear floor panel swb mk5
viewtopic.php?f=4&t=127587
vanmanloki
Postby RonTransitmk5 » Mon Mar 25, 2013 1:14 am
I remember when I did mine it seemed to take forever, but I got there in the end :lol:
RonTransitmk5
Postby RonTransitmk5 » Mon Mar 25, 2013 1:20 am
If I was you (or if I had to do my rear floor again) I would take Tim's advice on buying the complete rear replacement floor panel
I'd also budget for repairs to the chassis rails & rear spring hangers, you can also check/repair the inner rear arches easier while the floors out.
RonTransitmk5
Postby RonTransitmk5 » Mon Mar 25, 2013 1:22 am
Managed to identify & almost rectify the electric windows problem today. :)
Spent some time studying the wiring diagrams in my TIS & realised my problem.
Dug out my 12 volt tester & bingo, One of my switches is/was faulty!
The passenger electric window only works if you have a working switch on the drivers passenger switch & on the passenger side.
As soon I put 2 red bottomed switches on them the passenger electric window worked 100% :D
The all black switch that was originally on the passenger side is/was faulty
Managed to get it all installed & all the trim put back together :D
Now I just need to contact the seller of the doors & sort out a replacement switch, pop it on & then all will be working 100% :)
RonTransitmk5
Postby RonTransitmk5 » Mon Mar 25, 2013 1:28 am
Now looking into the best way to get the central locking 'remote'
RonTransitmk5
Postby vanmanloki » Mon Mar 25, 2013 2:06 am
its on order :) although i'm beginning to think maybe i bit off more then i can chew lol. i know i'm going to find a few nasty surprises once that floor comes up i just hope its not crazy bad :shock:
FORD BUILT TOUGH
vanmanloki
Postby RonTransitmk5 » Tue Mar 26, 2013 1:30 am
Managed to find a replacement electric window switch on ebay for a couple of quid so bought it :)
RonTransitmk5
Postby RonTransitmk5 » Tue Mar 26, 2013 1:31 am
What parts would I require to make the central locking remote?
RonTransitmk5
Postby robbie.cee » Tue Mar 26, 2013 8:02 am
There is a kit on ebay might work...
Comes with fobs relay box and solenoids...
Might work!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby RonTransitmk5 » Tue Mar 26, 2013 8:47 pm
robbie.cee wrote:There is a kit on ebay might work...
Might work!
Got a link m8 :)
RonTransitmk5
Postby RonTransitmk5 » Tue Mar 26, 2013 8:51 pm
Ford Transit mk5 Central Locking & Electric Windows installed, red tape is for the the drivers switch I am awaiting to comlete the install :)
RonTransitmk5
Postby RonTransitmk5 » Tue Mar 26, 2013 8:53 pm
Look what the postaman brought me, a pair of Bosch wipers just £13.51 delivered :D
RonTransitmk5
Postby RonTransitmk5 » Tue Mar 26, 2013 8:55 pm
Look what the postman brought me, a mk5 Ford Transit Cup Holder for MINUS £5 :lol: :lol: :lol:
RonTransitmk5
