Cheers guys,
I've been gassing up the stainless kitchen unit lately.
Thought id gas it all up whilst the unit is out of the van and then re-install it all ready to work.
Started off building a 5 branch manifold with a main control tap.
The 5 branches are for the: 1 - Hot Water, 2 - Hot Air, 3 - Cooker, 4 - Grill, 5 - Fridge.
It'll fit in a stainless section which will be bolted to the kitchen unit later on.
At the moment im still in the middle of putting a plain hinged flap on the front so all you would normally see is the single main control tap until the flap is lifted and then the rest of the controls can be accessed.
The whole unit will then fit just above the fridge and under the sink.
I'll get this little bit finished then I'll run the rest of the gas lines to the separate gas appliances, shouldn't take long..
Cheers Guys.......
