Puk, a troublesome fairy!
Re: Puk, a troublesome fairy!
Postby jonochap » Sat Mar 02, 2013 5:34 pm
Ah well, despite valiant attempts from the mobilevanman and expert spanner passing from myself, puk the troublesome has lived up to his usual self!
The 4 speed box is out but on inspection the clutch needed replacement. Good news was that the first class motor factors in maldon had one at 68 plus vat...bad news, not until tuesday.
Good news is that the prop shaft fits perfectly, bad news is the mvm will have to tailor a couple of bulkheads and redesign the main supporting bracket.
But! The exhaust fitted back to the manifold well and we also redesigned the carb setup to hopefully help with the standstill issue and also confirmed how to put in the erberspacher hand wash when it gets here...all in all a very fun and entertaining morning!!
Owner of not so troubled puk :)
jonochap
Postby jonochap » Wed Mar 06, 2013 7:40 pm
Just had the most fantastic drive ever in puk, such a hooge thank you to robbie, mutts, CE, blue transit, mahusive thanks to fred, big thanks to andy and alan, ralph9 mvm capt hook and everyone else who has helped supported and cajoled...there have been times that this has been a daft idea but this has made it so so so worth while...good luck with all your projects, may they have at least one night like this and many more :)
jonochap
Postby jonochap » Wed Mar 06, 2013 7:47 pm
Right, important bits before i get carried away, all of this is with the help time patience and understanding of mvm over the last few days...
Prob with the carb was cured by turning the fuel return pipe 90 degrees to the fuel supply pipe so we didnt have to take it back to the tank, this may help others
The type 9 was good for a petrol engine but fitting was a bit complicated...the mid location metal holder needed to be dropped and the chassis needed some angle grinder modelling to let the box and shaft sit straight. The floor plan needed some gentle hammer adjustment to get to reverse...trying to find a clutch on a saturday afternoon was a mare! And it took 2 days to deliver (include this in your plans) apart from that, pretty plain sailing for a spanner passer!
Good luck if youre reading this for the technical information...you always more than welcome to pop to Maldon and have a looksee if it helps!
jonochap
Postby jonochap » Wed Mar 13, 2013 12:19 am
Wall fitted handwash tonight, just a lickle bit of plumbing and sparks and should have hot hand wash on demand! Puk driving really nicely now, just need to get a bit of attention to the carbs i reckon...but someone was right (again...bah) speedo is slow, so all of you i chased on the m11 from transitmania last year, we were doing 70!!!
jonochap
Postby robbie.cee » Wed Mar 13, 2013 9:10 am
Dude great news but ate you still gettin vapour locked carb then?
Never ever had that problem with pinto...
Check timing not retarded, and if still happens I have spare fuel line get mvm to run a return to tank, will allow heat to be taken away from carb fuel acts like coolant!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby jonochap » Wed Mar 13, 2013 3:58 pm
Ah, interesting, thanks robbiemate, will do...learnt another valuable lesson today, never buy never fitted mk1 leaf springs on e bay as they have never been fitted and the bush is now obsolete :) oh the joy!
jonochap
Postby jonochap » Wed Mar 13, 2013 4:00 pm
Yes, still getting a little vapour lock but mvm has had so much to concentrate on, the carbs have had to take a back seat for a bit, no doubt he will have a view ;)
jonochap
Postby Muttley » Wed Mar 13, 2013 11:18 pm
Phew! And I thought I had problems :lol:
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby MinorMatt » Wed Mar 13, 2013 11:19 pm
No comment Andy :lol:
Postby jonochap » Thu Mar 14, 2013 12:48 am
jonochap
Postby robbie.cee » Thu Mar 14, 2013 9:06 pm
Don't forget I got Di fuel lines you can have to make a proper return to the tank if you want...
Tony lives 2 streets away from me!
Had
MAKE IT FIT
robbie.cee
Postby jonochap » Thu Mar 14, 2013 9:08 pm
Right, hand wash wired in and guess what, it dont work :( oh the joys...anyone fancy having a go at fixing an erberspacher? Getting a bit tired of trying to make things work now :( although the not working jenny was taken back very nicely and fiddled with, will get some petrol tomorrow and find out if thats ok now...
jonochap
Postby jonochap » Thu Mar 14, 2013 9:11 pm
Aw mate, yes, i havent forgotten and i know i am way overdue on the house calls :)
We set the return pipe at 90 degrees and its about a foot long, i may try timing and fiddling before playing with the return again. I reckon that the setup should have cured the return now, but who am i???
jonochap
Postby robbie.cee » Thu Mar 14, 2013 9:29 pm
Always welcome ere m8 I do Like elastic trickery n wires
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Thu Mar 14, 2013 9:31 pm
Also have timing gun that is adjustable.... Don't fiddle ,will do it accurately!
:wink:
Had
MAKE IT FIT
robbie.cee
