All About FLER
Re: All About FLER
Postby mealic » Wed Jul 13, 2011 10:10 pm
[quote= I was easily beating Mealic with his 2.3 swb low petrol mk6 at N weald[/quote]
Maybe not now Matt :wink: :wink: :mrgreen: :mrgreen: .
I`ve got some nice carbon steel tubes now (loads of `em) to share out .make some nice `zorsts I should think.You about this way with your welder soon??
`04 2.3 petrol/LPG
mealic
Re: All About FLER
Postby MinorMatt » Wed Jul 13, 2011 10:16 pm
I might be with a friends welder at "the unit" :lol:
Re: All About FLER
Postby mealic » Wed Jul 13, 2011 10:20 pm
MinorMatt wrote:I might be with a friends welder at "the unit" :lol:
Sat or Sun?I might pop over and show you the "tubes".
`04 2.3 petrol/LPG
mealic
Re: All About FLER
Postby MattBlackMinibus » Wed Jul 13, 2011 10:23 pm
ake wrote:I would be quite interested to run against you :D
"When the red light drops, the bullst!t stops"
Where were you on Sunday Ake? :lol:
Starting All Over Again
MattBlackMinibus
Re: All About FLER
Postby ake » Thu Jul 14, 2011 7:00 am
At home with no money :(
I'll make North Weald one day :)
Re: All About FLER
Postby MinorMatt » Thu Jul 14, 2011 3:42 pm
Fri/sat/sun next week - most likely fri/sun afternoon
Re: All About FLER
Postby MinorMatt » Mon Jul 25, 2011 8:53 pm
Done about 1000 miles with it (including 2 at N weald :lol: )
But my diff is now making some really nasty noises at full lock (I have been leaving a few 11s around the roads of sussex :oops: ) and the rear brakes have started to shudder very badly from braking at 60mph +
Im hoping a diff oil change and some new shoes will sort it - there was an imbalance at the back at the last MOT and hopefully it will sort that out too
Re: All About FLER
Postby blue estate » Mon Jul 25, 2011 8:59 pm
So you'll be coming in the escort on sunday then :lol: :wink:
blue estate
Re: All About FLER
Postby MinorMatt » Mon Jul 25, 2011 9:20 pm
no...
Re: All About FLER
Postby blue estate » Mon Jul 25, 2011 9:21 pm
MinorMatt wrote:no...
Should i pack the tow rope then (only joking)
blue estate
Re: All About FLER
Postby MinorMatt » Mon Jul 25, 2011 9:54 pm
its only noisy at hard lock
Re: All About FLER
Postby madmark » Tue Jul 26, 2011 12:23 pm
MinorMatt wrote:Done about 1000 miles with it (including 2 at N weald :lol: )
this is the problem with all this power now :shock: everything will go wrong :roll: :roll:
Re: All About FLER
Postby MinorMatt » Tue Jul 26, 2011 8:11 pm
I don't think its putting out more than 120-130 at the moment Mark so not a lot more than the 115PS you could get out of the factory...
I knew the brakes needed new shoes before putting the V6 in but never got round to doing it :oops:
Re: All About FLER
Postby MinorMatt » Fri Jul 29, 2011 3:19 pm
well I have re-done the timing - engine seems smoother manouvering around the garden, so hopefully a couple more horses may be released
I have also replaced the brake shoes, both cylinders were totally free (good news) and all went pretty well. Had to take 1 drum off to re-adjust but other than that all was easy.
I also checked the diff oil level... I got about 1/2 litre in it :shock: (thats after about 1000 miles since I put it in and topped it off) the pinion seal is leaking badly so I think I need to get it sorted :lol: I never have much luck with oil seals so I think I may pay to get it done :shock:
The diff noise at full lock has also stopped, so I guess it was due to the low oil level
Re: All About FLER
Postby blue estate » Fri Jul 29, 2011 6:50 pm
So we will see with fler at hayling on sunday :?: :wink:
blue estate
