Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby MinorMatt » Wed Aug 01, 2012 7:46 pm
I have 2... thanks for asking :?
Postby IgorVigor » Wed Aug 01, 2012 7:53 pm
robbie.cee wrote:Anyone got a compression tester?
Buy one....they arent expensive, and are very useful for quick diagnostics 8)
IgorVigor
Postby robbie.cee » Wed Aug 01, 2012 8:00 pm
Matt that was a strange answer, you havin a bad day?
Igor will do cheers mate.
when i fit it does piston need to be at tdc or will it "self adjust"?
do i remove the other 5 plugs whilst testing to make cranking easier?
do i crank by hand or on starter?
cheers guys
ps any idea of order of rocker adjustment on a v6??(long winded ill bet!)
8)
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Wed Aug 01, 2012 8:06 pm
Rob mate, you need a starter AND a flywheel to do a compression test, and I have your flywheel :lol:
It might take a while to explain how to adjust valve clearances, but I am sure all will be revealed tomorrow evening at the meet :D
Postby robbie.cee » Wed Aug 01, 2012 8:09 pm
Sweet. theres a bit of a change on cards for the meet as the venue's bods are apparently also as a sideline catering for olympics so said wont be open tomo evening or any evening during olympics :evil:
never mind we have 5 macdonalds 3 kfc numerous pizza huts and even my house if no one else shows!
Possibly gonna be at Pitsea, ill get on the case in the relavent thread !
Had
MAKE IT FIT
robbie.cee
Postby mobilevanman » Wed Aug 01, 2012 10:57 pm
Rob i still have my comp tester it is in my shed ur welcome to use and hang onto it
why not if u dont someone will
mobilevanman
Postby robbie.cee » Wed Aug 01, 2012 11:09 pm
sweet . heads are on now just need torquing up then inlet manifold etc. cant see how the dizzy skew gear meshes with the cam gear as they look at different angles. does the dizzy just drop into the hole on block top side and rest (ish) on the cam gear? :twisted:
Had
MAKE IT FIT
robbie.cee
Postby MinorMatt » Thu Aug 02, 2012 8:30 am
You only asked if anyone had one... not if you could borrow one ;) :lol:
Postby robbie.cee » Thu Aug 02, 2012 9:55 am
well i would have thought it would be obvious i was after a local one, not borrow one from hundreds of miles away ... :lol:
still tony got one and he 3 streets away !!! :D
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sat Aug 04, 2012 9:18 pm
Well had a few hours more "tinker time" so now heads are torqued up, inlet manifold on, 38DGAS on, distributor fitted and fixed crack near thermostat from a previously over tightened bolt!
Wahoo!!
Had
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Sat Aug 04, 2012 9:27 pm
It will be going in next weekend then 8)
Postby robbie.cee » Sat Aug 04, 2012 9:44 pm
oh YES!!! remind me #1 inlet tappet loose needs addressing!! electronic ign n rotor ordered! hmmm 14"x3" chrome pancake filter or not? :lol:
Had
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Sat Aug 04, 2012 9:48 pm
I'll measure under the bonnet of the Surrogate in the morning for you, just to make sure that a filter that size will fit!
Just booked your van in, next weekend it is then 8)
Postby robbie.cee » Sat Aug 04, 2012 9:53 pm
sat 11th? sweet
Had
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Sat Aug 04, 2012 10:04 pm
That will do nicely!
