Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Mk1 Minibus V6 24v cosworth
Postby Luke » Thu Jun 04, 2009 9:14 pm
here it is in the back of the van :D all being well fully welded and painted for the weekend :mrgreen:
also while it was on i measured the prop 1820mm (posted here incase i forget) :lol:
Postby rover » Thu Jun 04, 2009 9:35 pm
Much better mate :D
Looking forard to seeing it at the truckstop!
Rover.
rover
Postby Luke » Thu Jun 04, 2009 9:37 pm
cheers :mrgreen:
16 days :shock: :lol:
Postby redeemer » Thu Jun 04, 2009 10:17 pm
but now are you allining the gearbox and engine accordingly, or when the load is taken on the springs it will be back to normal?
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby Luke » Thu Jun 04, 2009 10:23 pm
redeemer wrote:Luke
it's all on factory mounts i've had to alter the gearbox mount a little to get clearance but other than that - nothing :lol:
the back axle is as it was before - just needs the prop shortening now :D
i think with the angle of the diff as the power is fed through it the reaction will rotate it level - as that is when the most wear will occur :D
Postby Luke » Fri Jun 05, 2009 5:52 pm
All welded up and painted 8) i bought a tin of black hammerite, opened it up and it's more like a gun metal grey :? :mrgreen: looks well tho 8) i'll give it another coat later :D
took the propshaft down to Propshaft technologys Rotherham £100 for a new end and shorting and balancing - should be done wednesday :D
popped into the machinists and unfortunatly the halfshafts havent been started :( bit of a setback as ive still got the caliper brackets to make and i can't start them untill the halfshafts are back in, disks on and all lined up :)
didnt get chance to get the hub seals but found they are £10.49+vat each from evans halshaw fords parkgate :D Finis Code 3896454 but i'll pop in tomorrow morning and they should be here for wed/thursday :D
still all on target for the northern meet :D
Postby madmark » Sat Jun 06, 2009 2:34 pm
8) great work mate! 8)
Postby Luke » Sat Jun 06, 2009 4:19 pm
latest pic all painted up :mrgreen:
got the seals ordered :D price went up £28.87 inc vat tho :roll: all being well they'll be correct and here for wednesday :D
Postby AlanN » Sat Jun 06, 2009 4:21 pm
You can come and do mine :lol: dont forget your paintbrush
Postby AndyG » Mon Jun 08, 2009 11:10 am
Brand new :!: :mrgreen:
Postby Luke » Mon Jun 08, 2009 5:46 pm
got prop back today 8) haven't measured it up but it looks about right :lol:
just waiting on :arrow:
hub seals from fords - due wed
diff oil still not enquired about this :roll:
halfshafts from machinists - main thing that could hold me up
once i have the half shafts i need to make brackets to hold the calipers
then i'm done :lol:
Postby transitgeoff » Mon Jun 08, 2009 10:23 pm
quality work mate...as to be expected :D :D
transitgeoff
Postby Gurj51ngh » Mon Jun 08, 2009 10:28 pm
Looking good that 8)
Gurj51ngh
Forums Loudest Van!
Postby luci_sicoe » Mon Jun 08, 2009 11:30 pm
Top work Luke ....., as usual 8) 8)
Chears!
FORD TRANSIT 2.5 L TDi, LWB High Top, MK5 .......................... love it and never leave it!!!!
luci_sicoe
Postby Luke » Wed Jun 17, 2009 9:01 pm
well i've given up trying to get the axle on for the meet - spoke to the machinist today and the half shafts will be done friday - so it doesnt really give me enough time to make and fit the caliper brackets :)
so i've dropped another diff in the old axle case and put the old axle back on - the only problem i can see is now i've had the prop shortned i hope there will be enough side in the sliding joint to cope :? but theres always a way round - longer flange bolts and a few packets of washers mabe :shock: just best not go over 30mph :lol:
but 95% sure it will be at the meet :mrgreen:
