Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover The ESSEX COMETH!
Postby robbie.cee » Wed Aug 08, 2012 4:43 pm
Now for the long bit. The following is "how to fit electronic ignition in points distributor" into a (black) Ford Motorcraft distributor
Tools required - small ish screwdriver, and spanner or what ever your coil uses to connect wires to terminals.
Step ONE, remove cap and put somewhere safe.
Step TWO, remove Rotor Arm, again put somewhere safe. or better still, up rate to a red one from Accuspark!
Step THREE, remove the 3 small screws holding the points and condenser. DONT DROP EM! put aside safe.
remove the points , condenser and any wiring still attahed. put aside. should leave you with this...
Step FOUR, now we need to free the wire going through the plate. on a Pinto you can wiggle out of the gap but on the Essex there are 2 tiny screws that need to be loosened or removed and CAREFULLY LIFT PLATE and remove wiring.leave screws loose or out and safe
Step FIVE, open your packet, it should contain :- new pickup, wiring, magnetic ring and some heat transfer compound. also a tiny zip tie, which i discarded as it chaffe's on the mechanism!
Now the new kit fits where the condenser went. Dont panic if this doesnt make sense, as the screw holes will only line up in one place. basically NOT where the points were!
first thing to do is get the little plug off of the wires from the new item. there are tiny catches that lock the contacts into the plug. tweezers or similar bends to release with a tug!
now feed the two wires AND the grommet through the same hole as original wires, leave slack in distributor, but bend catches and re fit plug now, using other bit of wiring as guide for what wire going where... loosely refit the 2 screws in the top plate too. this allows for final adjustments !
Step SIX, wearing gloves cos its messy, carefully open the heat transfer compound stuff, rip as close to edge as poss not in center... Now TOTALLY cover the base of the new pickup. like this ...
Step SEVEN, we now need to position the pickup- REMEMBER its going to the condenser s old position! screw down loosely. Loosely re route wiring to below the rotor shaft- the advance twists this way.
Step EIGHT, remember that old condenser? i ripped the tag off it and bastardised a wire holder cos on the last one of these i did in the pinto the zip tie seemed inadequate as theres only tapped holes and tight corners against metal there. screwing down a metal plate seemed better! wires will need a bit of extra mechanical protection so i wrapped a bit of insulation tape round the area that might wear... screw the rolled/bent metal around so wires are held within, screw hole left from points is a good a place as any to fit plate to.
Step NINE, pick up the plastic magnetic ring and examine it. there is a top side and a bottom side . you can see the flat top side here... Carefully place on rotor shaft, might need a slight twist and push to get it fully home.
THERE SHOULD BE NO CONTACT WITH PICKUP this is why we didnt tighten up screws yet!
Step TEN, Tighten all screws that you removed and refit the Rotor arm. It will only go on one way round, and if the spring on top is limp and not standing proud, if strong enough not to break try lifting slightly. Up rated red ones are £5 on ebay from Accuspark tho!!! If its pitted be a good time to replace. otherwise electronic ignition wont perform as it should.
BEFORE you refit the distributor cap, check inside - look at the state of the brass terminals- does it need replacing????
Now refit Cap, check clips are secured and vacuum pipe still connected(if applicable).
Step ELEVEN, final step.... your old dizzy had only one wire from it to the (-) negative terminal of the coil. the new kit has 2 wires. dont panic!!
Basically you now connect the BLACK wire of new kit to the (-) negative terminal of the ignition coil. i had to extend my wires but the old stuff provided some of what was needed!
The RED wire (extended as required) literally goes straight to the (+) positive terminal of the coil. ENSURE EXISTING WIRE STAYS CONNECTED TO THE COIL (+) AS WELL AS YOUR NEW RED WIRE. this terminal is the only one with 2 wires on it...
HAVE YOU TIGHTENED EVERYTHING AND REMOVED YOUR TOOLS FROM UNDER THE BONNET??????
All done??? KEYS IN, TURN HER ON! should be bang on and not need adjustment if you were happy before.
any fine tuning can be done by loosening dizzy locking bolt and twisting dizzy with engine running either way til it sounds best and revs up happiest, whilst still ticking over well on idle...
ANY PROBS PM ME!!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Wed Aug 08, 2012 7:17 pm
So who's been watching Blue Peter now then? :lol: :lol: :lol:
At least we won't spend ages getting it to start!
Postby robbie.cee » Wed Aug 08, 2012 7:26 pm
dieselhead123 wrote:So who's been watching Blue Peter now then? :lol: :lol: :lol:
Have just been reassuring emma it wont be another epic build...fingers crossed... got some family leaving cos emigrating party on sat night so i gotta try to be there or forever be moaned at !!! :lol:
was aiming to be with you by bout 0830 if thats ok with you mate?
Had
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Wed Aug 08, 2012 7:50 pm
Yes mate, 8.30 is fine. Not sure that it will be achievable in one day, might need some 'tinkering time' :lol: .
But I will make sure you get back for your do, have to get done reasonably early myself, it is my birthday :D
Postby robbie.cee » Wed Aug 08, 2012 8:01 pm
Your jokin, working on your birthday? wow, ill get cake then!!!! MMMMMM
Had
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Wed Aug 08, 2012 8:04 pm
And DON'T ask how many candles :lol:
Postby robbie.cee » Wed Aug 08, 2012 8:05 pm
:lol: 6 spark plugs as candles :lol: nice chocolate cake for breakfast 8)
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Fri Aug 10, 2012 9:06 pm
WOW!! that was heavy!
BIG BIG THANKS to FordBoyNick and MobileVanMan (and AlanN) for helping me shift that iron lump into my van! 8)
Defo owe ya some beer for that!
Now we can proceed with operation "triple sword" or the Essex V6 transplant down at LIGHT COMMERCIAL SERVICES in Kent!
:D :D :D
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Fri Aug 10, 2012 9:37 pm
Oh, it was no problem!!! :lol: :lol: :lol: seeing as I missed the lifting bit :oops:
Postby dieselhead123 » Fri Aug 10, 2012 10:21 pm
Wussy 'Essex Boys'... :lol:
Takes three, or was it four of you to lift an engine :?:
Used to fit them single handed this side of the river :lol: :lol: :lol:
Postby jonochap » Fri Aug 10, 2012 10:26 pm
Awwww mate, so glad for you, hope the op goes well :)
Owner of not so troubled puk :)
jonochap
Postby robbie.cee » Fri Aug 10, 2012 10:40 pm
Me too man, me too!!! 8)
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Fri Aug 10, 2012 11:02 pm
Had to have a rosie lee and a fag after all that :lol:
Postby robbie.cee » Fri Aug 10, 2012 11:22 pm
Cheers again guys would still be in garden or id be in hospital otherwise! nearly lost my right toes too! :lol:
Had
MAKE IT FIT
robbie.cee
Postby jonochap » Fri Aug 10, 2012 11:34 pm
Thats why god gave you 10!
jonochap
