Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Mk1 Minibus V6 24v cosworth
Postby MattBlackMinibus » Tue Jul 14, 2009 9:42 pm
MinorMatt wrote: Or make them adjustable length?
Good idea :idea:
Starting All Over Again
MattBlackMinibus
Postby Luke » Tue Jul 14, 2009 10:07 pm
rover wrote:I wouldnt worry about it vibrating when jacked up, most RWD vehicles will do it without any load on
thats good to know 8) it's not really the sort of thing ive ever done before :lol: i'm feeling happier now :mrgreen:
MinorMatt wrote:weld a small amount in?
i think thats what i'll do cut em and fit a pipe in between and weld back up - then eventually make some new ones :D
spring hangers are back off now ready for modding (only a little job) and all being well back on tomorrow and i'll at least have the handbrake working :D
Postby winterheating » Tue Jul 14, 2009 10:59 pm
my bmw318 did the same, jacked it up put it in 5th, and floored it, thought id broken something it was vibrating that much :lol:
winterheating
Postby AlanN » Wed Jul 15, 2009 10:29 am
Didnt Paul's (BrownyV6) have some kind of adjustable affair on it! I was looking for some pictures, its not in his progress thread.
Postby BROWNYS V6 » Thu Jul 16, 2009 9:14 pm
yes adjustable :wink: made em that way so when i lower the back i can adjust them longer or shorter to fit back on :)
BROWNYS V6
Postby Luke » Thu Jul 16, 2009 9:18 pm
hmmmm adjustable :idea: :idea: might do the next ones adjustable :D
so far with these ive cut them and put a small pipe inside - i've got them on the van - i'll clamp them and tack them up - remove and fully weld :D i would have been done tonight but it started raining :( :lol:
also modded the spring hangers they are back on but still not piped up the calipers :)
Postby MattBlackMinibus » Fri Jul 17, 2009 10:33 am
Luke wrote: i would have been done tonight but it started raining :( :lol:
Damned weather's being a right pain :evil:
MattBlackMinibus
Postby Luke » Sat Jul 18, 2009 12:03 pm
getting there now :lol:
pics of the modded hanger brackets :D
and the max clearence - this is with the outer pad missing so in reality with a fully worn pad it will never get this close :D
Postby Luke » Sat Jul 18, 2009 12:09 pm
this was how i lengthened the tramp bars - i made the clamps from 1" angle with a bit of flat welded on - inside is a bit more pipe - its now tacked together on the van and i'll remove them and fully weld up :D
just shows how much movement there is :shock: no wonder they wouldnt fit :lol:
Postby ginsambo » Sat Jul 18, 2009 12:59 pm
Luke, bit off track...but seeing how your doing so well...
..Do you reckon it would be feasible to mount a large machined spacer behind the hub permanently attached to it by new longer press fitted studs, and then mount a flat disc to tapped bolt holes in this new spacer? - It would buy extra wheel clearance room but hub bearings would need reassembly every time you needed a new disc, but then you could use standard el cheapo discs?? Think longer press fitted studs are a potential weak point?
Cheers!! - I'm still trying for Mk5 Twin wheel 6 stud discs and theres no way any disc will fit conventionally!!
ginsambo
Postby Luke » Sun Jul 19, 2009 10:03 am
do you mean on a 6 stud? cos i'm not really up on the 6 stud ones mate :) but sounds a plan - if you want start a thread put some pics up and we could mabe come up with some ideas (i like a challange) if the studs are supported you shouldnt have a problem if the hub is holding them and you only have the shear on the disk at one side and the wheel at the other :D
Postby Luke » Sun Jul 19, 2009 10:13 am
back to progress :)
fully welded the bars got them fitted back on - took the van for a spin :D booted it and it did seem better i dont know if it's psycological or this LSD working its magic but time will tell :lol:
but i've had an intermittent problem with the n/s front caliper dragging but on the run it got so bad the van wouldnt even freewheel down hill :lol: got back and took the caliper off but it was free (cyls easly pushed back) but i put another caliper on just incase and it but it was the same so i think it might be the flexihose :) iveordered a new one should get thet early next week, but i also got a slight leak of fluid between the master and the servo - it was proberbly as i'd been pushing hard on the pedal to bleed the system but i'll keep an eye on that for future problems :(
Postby AlanN » Sun Jul 19, 2009 12:49 pm
That leak was the first signs that my master cylinder was on the way out, Im sure there are a few MK2 master cylinders on fleebay at the moment, Im sure youve got a spare anyway :D
Postby Luke » Sun Jul 19, 2009 1:07 pm
i dont think ive got a spare master but i was thinking of 'upgrading' to a mk6 servo and master cyl like geoff did :D
Postby AlanN » Sun Jul 19, 2009 1:20 pm
Good idea
