He'll be fine
Look forward to it mate
100 T280 wrote:
Belt and tensioners are different, the only pipe that is common to both FWD and RWD is the evaporator to receiver dryer one, pretty sure compressor is different, condenser fits to the water radiator using rubber bungs, therefore, radiator has to be correct, RWD with A/C rad. is different / longer than standard RWD one.
FWD and RWD with A/C radiators are the same dimensionally, but hose connections are different AFAIK.
You should be ok with your existing dash loom though.
Guy88 wrote:Only pipe that is different according to microcat is the compressor one all the rest are the same (age dependant)
100 T280 wrote:Guy88 wrote:Only pipe that is different according to microcat is the compressor one all the rest are the same (age dependant)
There are two pipes to the compressor, one from the evaporator to the compressor which includes the expansion valve, and one from the compressor to receiver / dryer, both different between FWD and RWD, unless MicroCat is showing it as one assembly, and that won't be cheap.
I assume that the heater box multiplug on the wiring loom is missing the A/C wiring then?It's relatively easy to wire it, but are you going to get the proper loom?, then you can do it whilst you've got the dash apart!
100 T280 wrote:Yes, you're right, wasn't fully awake......usually try to engage brain before typing
Guy88 wrote:Just got to make a moung to bolt the compressor to the engine now
