Hi, just posting my MK5 2.5D SWB HI-TOP camper build.
Re: Hi, just posting my MK5 2.5D SWB HI-TOP camper build.
Postby Paul 1 » Sat Oct 31, 2009 10:27 pm
Superb work as ever :)
The cable loom looks tidy to me :lol:
54 plate 260 MK6 SWB Exec pack 85 ps soon to be reemapped. Dead locks and arma plates on rear.
Paul 1
Postby imustloverust » Sun Nov 01, 2009 12:11 am
Was there supposed to be a photo of mesy wiring in there? :lol:
That console would keep me entertained for weeks too. Great work. Perfection as usual! :)
imustloverust
Postby dachre » Sat Nov 14, 2009 5:51 pm
Cheers Guys..
Just been playing with the gas appliances and tidying things up this week.
Fitted the Smev grill in the table top then got it to work, it has one little burner and one big burner.
Then fitted the Smev oven and got that to work. It has one long burner in the top as well as a little cooking light on the back.
Then fitted the 3-way gas fridge and it didn't look like it was going to work. I had cleaned and tested the fridge gas mech before fitting it so i couldn't figure out what was going wrong. I couldn't see a gas flame through the spy glass so i had to take the fridge back out. When i did take the fridge out and test it everything was fine.... I then figured out the back of the spy glass was very dirty and i couldnt see through it... :lol: ... The pilot had been igniting and staying lit the whole time, just i couldn't see it.... :lol: ...
So i then refitted the fridge, got that to work and everything was fine... it gets cold enough to freeze ice cubes in 3 hours... and it take about a day for them to defrost if the fridge gets turned off.
The Propex air heater has been fitted for a while but I've only now gassed it up and tested it. Works a treat.
I fit all the gas appliances then check all the fittings with watered down washing up liquid looking for bubbles. Then i check everything again using a special LPG Leak analyser. Its very acurate and finds the slightest trace elements of gas. Its much more accurate than bubbles... :lol:.. I'll do a drop test when everything is finished as i still have to gas up the Carver water heater.
Tested the timer that i fitted onto the Propex unit and that works fine too. Comes on, switches everything on, then switches everything off, ect...
The twin battery tester works good too. Shows the difference between the two batteries and if any of them are under charged.
So its actually starting to get like a proper 'take anywhere' camper now.
Next thing to do will be to connect and test the Carver water heater.
Cheers everyone... :) ....
dachre
Postby kex1889 » Sat Nov 14, 2009 8:09 pm
Dachre, You are a god, thank the lord you're doing this for yourself cause commercially this would cost a fortune. TOP TOP QUALITY!
Keep it up, I always smile when I see you have posted!
kex1889
Postby dachre » Sat Nov 14, 2009 8:22 pm
Cheers Kex,
yeah, i think i would of gone bankrupt ages ago.... :lol: ...
I think the stainless steel kitchen unit on its own would cost a fortune in labour.... :lol: ... and then there's the time consideration........I think its a 2 year build date....... :lol: :lol: :lol: :lol: ........
I dont think that the SWIFT or HYMER Motorhome companies have got anything to worry about with me...
dachre
Postby kex1889 » Sat Nov 14, 2009 8:35 pm
I beg to differ, all these companies should see your work and aspire to this level of engineering and your new definition of QUALITY.
kex1889
Postby 100 T280 » Sun Nov 15, 2009 10:23 am
:shock: Lovely! 8) 8) 8)
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby ake » Sun Nov 15, 2009 7:06 pm
Superb work as usual, remember and allow for a little bit of ventilation behind all switch gear cos it will get cosy in there :wink:
Postby dachre » Sun Nov 15, 2009 9:26 pm
thanks guys... :D ...
Hey Ake, the ZIG instruction leaflet says to put a couple of air holes by the Zig unit but I'm gonna put some at the base of the Zig unit then at the top/side of the control panel to allow air from the base of the Zig unit to travel up past the back of the control panel and then exit at the top creating a good air flow passage from top to bottom.
I just don't know how warm the Zig unit is going to get, especially when the 240v hook up has been connected.
Might be a good place to dry the dishes... or perhaps i could hang a little clothes line in there..... :lol: ....
Cheers guys.... :D ..
dachre
Postby ake » Sun Nov 15, 2009 9:35 pm
I dont know why I even bother to post, cos you always have the right answer to any query I raise :wink: :D :D :D :lol:
Postby AlanN » Sun Nov 15, 2009 9:41 pm
speechless 8) 8) 8) , hope your going to do guided tours when YOU come to Transitmania next year
Postby Nadjenka » Sun Nov 15, 2009 9:48 pm
Dachre, thank you for your posts, this is really inspiring and makes me get out and try things I have never tried before :lol: Top work, excellent pictures, I really can't wait to see your camper in one of the meets :!: Keep up the great work... :mrgreen:
Nadjenka
Postby Paul 1 » Mon Nov 16, 2009 12:34 am
More great work, you must be almost there now :)
Paul 1
Postby kennystag » Mon Nov 16, 2009 9:11 am
Hi mate, where did you get the twin battery tester from.
cheers
kenny
kennystag
Postby Anton2k3 » Mon Nov 16, 2009 1:45 pm
I'd like to know that too, and the water level gauge and light switches!
Ta
Anton2k3
