My MK3 cosworth
Postby Guy88 » Fri Mar 23, 2007 9:20 pm
SORTED
MOT tomorrow 8) 8)
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Fri Mar 23, 2007 9:40 pm
Guy88 wrote:SORTED
MOT tomorrow 8) 8)
8) What was it :?:
Postby Guy88 » Fri Mar 23, 2007 10:18 pm
Andyg wrote:
Guy88 wrote:SORTED
MOT tomorrow 8) 8)
8) What was it :?:
the Throttle position sensor was worn so it would rev then vibrate, loose contact and put it in to auto shutdown just like an EPIC throttle :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Sat Mar 24, 2007 4:11 pm
Never made the MOT :( :(
Re booked for monday :)
Shese pretty much done apart from lack of fuel at high revs which i think is the swirl pot output :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Sat Mar 24, 2007 8:30 pm
Some more pics now shes back together.
Had to replace my low pressure pump because it couldnt keep up at high revvs and the swirl pot emptied :shock: :shock:
New Facet red top
Swirl pot
What people see
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
pipe
Postby custom » Sat Mar 24, 2007 9:04 pm
wats the big pipe at the front going over the engine mine hasnt got one
custom
Re: pipe
Postby Guy88 » Sat Mar 24, 2007 9:12 pm
custom wrote:wats the big pipe at the front going over the engine mine hasnt got one
Radiator top hose :oops:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby custom » Sat Mar 24, 2007 9:15 pm
wat rad have u used then i got mine off a sierra and the pipes from the engine fir perfect
custom
Postby Guy88 » Sat Mar 24, 2007 9:17 pm
Mines the pinto one :(
Couldnt find a sierra :(
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sat Mar 24, 2007 9:17 pm
custom wrote:wat rad have u used then i got mine off a sierra and the pipes from the engine fir perfect
i think sierras have different sized rads in - i measured a few up and a twin cam one wouldnt go in a transit mk3 :(
Postby custom » Sat Mar 24, 2007 9:20 pm
ahh i see maybe with mine being a mk5 its a different size then
custom
Postby Guy88 » Sun Mar 25, 2007 5:49 pm
I decided today to put in a return from the swirl pot to the tank 8)
Also did a little bit of welding.
One question. thi pipe i have T'd into for the return runs up the filler neck and joins at the top. looks like its come from the top of the tank adn its 16mm I/D. what is it :?: Iv found the small breater and its not that but it connects next to it :? :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Mon Mar 26, 2007 10:35 am
FAILED :cry: :cry: :cry:
But i now know what needs doing :D :D
Basically
Windscreen banners got to come off
Handbrake lever comes up too far
Drivers side headlight not working on beam (was when i left home)
N/S headlamp aim too low
Drivers side brakelight fooked
Brake pipe catching on spring
Lower steering U/J
exhaust leaks and catches X member
Bottom ball joints
O/S rear spring hanger
New sills both sides
front crossmember
And rear brake balance
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby custom » Mon Mar 26, 2007 10:53 am
gutted for you mate least u can sort it all relativly cheeply as u can do most of it ur self good luck
custom
Postby Guy88 » Mon Mar 26, 2007 11:11 am
Im trying to get it done so it only needs a partial retest.
Just ordered sills X member and spring hangers 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
