Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby robbie.cee » Wed Aug 15, 2012 11:52 pm
nah ill be grinning like the cheshire cat :P
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby jonochap » Wed Aug 15, 2012 11:54 pm
True dat! Whats next???
Owner of not so troubled puk :)
jonochap
Postby robbie.cee » Wed Aug 15, 2012 11:56 pm
a surprise or two for the Mania :lol:
Had
MAKE IT FIT
robbie.cee
Postby jonochap » Thu Aug 16, 2012 12:19 am
jonochap
Postby robbie.cee » Thu Aug 16, 2012 9:02 pm
Been back to Hoo this afternoon, got some more work done with The Man, Dieselhead!
The 'zorst looking pretty, shame it'll be hidden away under the van! :lol: And yes its a slag fitting it- 2 man job defo :wink:
I needed a good scrub after that!!! :lol:
Tappets are now all adjusted so we are almost ready to fire up! Literally only need a few water fittings(which reminds me i must go in shed!) stick a few hoses here and there, Thermostat needs fitting in housing, and then thats it!!! not long now, vid soon !!
Big thank you due to Tim for all your hard work that has gone into this project, not just mine,the whole LEZ affair!!
Especially as the countless hundreds of hours and pounds that have been spent in the developmental stages, before even getting to a working prototype stage!
We Salute You Sir!!!! 8)
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Fri Aug 17, 2012 10:50 pm
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
http://youtu.be/vsO_O_dykg0
sh*t sound quality- from my phone. the high pitch noise is a steel timing gear. live with noise, never shred teeth n smash valves in!!! Nylon gear quiet but may destruct at any time without warning, like cologne v6 too!
enjoy more soon im knackered!!!
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Fri Aug 17, 2012 11:25 pm
just gotta sort out a few leaky core plugs, got new ones, and few minor leaks at fittings where 2 different metals meet, bit of ptfe tape around the threads. wiring for fan needs attention as fan failed to work, will sort these little bits out tomo!
cannot friggin wait to get her out on a motorway :lol:
Had
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Fri Aug 17, 2012 11:50 pm
Glad you are a happy bunny mate 8) 8) 8)
If was good to hear it run.
See you in the morning!
Postby AndyG » Fri Aug 17, 2012 11:55 pm
Well done :!: :D
Now what's the torque and PS figures for this engine :?:
Postby AlanN » Sat Aug 18, 2012 9:27 am
Well done guys, i did say about straight cut timing gears :lol:
Postby IgorVigor » Sat Aug 18, 2012 9:50 am
Love the sound of metal timing gears!
One reason I like the Honda VFR RC30 :D
IgorVigor
Postby robbie.cee » Sat Aug 18, 2012 10:18 am
AndyG wrote:Well done :!: :D
will get the lift and timing values from the camshaft then we might be able to get a half accurate reading til i get on a dyno 8)
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sat Aug 18, 2012 10:20 am
AlanN wrote:Well done guys, i did say about straight cut timing gears :lol:
Yeah and Burtons said wont refund due to noise on the website,still got it anyways - but not bothered bout the whine really, like a supercharger whine :lol:
be going back down in a while to sort out fan wiring etc 8)
Had
MAKE IT FIT
robbie.cee
Postby layalog » Sat Aug 18, 2012 9:28 pm
and then it was done bet your well happy rob
its not leaking, its just another tear
layalog
Postby robbie.cee » Sat Aug 18, 2012 11:37 pm
oh yes mate.
last odds and sods done today!
It occurred to me late last night in bed as i lay there sweating my bollocks off that the electric fan i recently got wouldnt be man enough for the Essex, fine in pinto, but the extra 1000 cc s and 2 pistons gets very very very hot! especially as its cast iron!!!
Tim had these kicking around...
now wired up negative switched relay switching the negative side of fans, into a 60A fuse next to battery with thick wire
The two o/s core plugs were fooked. i botched one but leaked still so Tim whipped em out and sikaflexed and drifted home two new plugs. Lucky i got em really and least i got spares!!! Not bad for a 40 odd year old engine!
The test drive was sweet, pulled effortlessly and sounded the tits as i wound up the revs! with the small steering wheel and the steel timing gear noise tis like driving a dodgem rapidly !!! I LOVE IT!!!! :D :D :D
Cannot thank Tim at Light Commercial Services enough, the dude even worked on his birthday ffs!!!! lots of beers for ya at the 'Mania my friend!!! 8)
Had
MAKE IT FIT
robbie.cee
