Mk1 transit project
Re: Mk1 transit project
Postby tonypastie1 » Wed Aug 22, 2012 6:18 pm
Well
I got corsa unit coming but
Nobody seems to
No how to fit it or shown me yet :)
tonypastie1
Postby captain hook » Thu Aug 23, 2012 12:00 am
tonypastie1 wrote:Well
Nobody seems to
It's not a thing to describe on a thread or P.M.
Do a search on the 'net.....
Been covered on many other Forums 8)
captain hook
Postby Vandalism » Fri Aug 24, 2012 11:15 am
Postby alinomie » Sun Aug 26, 2012 7:10 pm
corsa system is easy to fit. i might miss a few bits here
1. remove steering wheel and indictor stalk
2. mark where outer sleeve of column comes threw the bulkhead grommet
3. remove and cut sleeve and refit the sleeve to steering box and so grommet holds it at bulhead
4. with steering shaft now exposed, measure length of corsa PAS from splined end to the end which universal joint fits (fit the corsa universal joint) and measure to where the steering shaft would need to go into the universal joint
5. measure it again
6. measure it again
7. then measure the same distance on the exposed shaft of van from splined end down
8. measure it again
9. measure it again
10. now cut it off, now grind a squared end onto shaft of van so corsa universal joint will fit it, (i welded mine on aswell as pinch bolt)
11. i had to cut braket of pedal box to where steering column bolts onto dash
12. now modify bracket on back of PAS to meet the pedal box, i welded mine together
13. i was lucky the top corsa holes mated to the orginal transit holes at dash
14. wiring you need a mk2 mania control kit, very easy to wire up and adjust
thats a rough guide, just measure it over again and think about what your doing before you cut
alinomie
Postby tonypastie1 » Sun Aug 26, 2012 8:48 pm
good guide chap dont surpose u took any pictures ?
and where r u based as i would,nt mind some help with mine
tonypastie1
Postby alinomie » Sun Sep 30, 2012 3:33 pm
I'm thinking of putting my van up for sale, not sure what to ask for it. Whats a mk1 transit with a genuine 44k miles worth? in the condition mine is in
alinomie
Postby oldyellar » Sun Sep 30, 2012 5:10 pm
alinomie wrote:I'm thinking of putting my van up for sale, not sure what to ask for it. Whats a mk1 transit with a genuine 44k miles worth? in the condition mine is in
how much do u want for it?
oldyellar
Postby richieRS75 » Fri Jul 14, 2017 5:09 pm
hi new here,that transit you have is the most nicest transit ive seen.
and using the ford rs livery is perfect.
im actually making a mk2 model kit with the same livery as yours.
could i please ask what the paint colour or code is you used on the wheels please?
richieRS75
Postby Vandalism » Sat Jul 22, 2017 2:41 pm
very nice, highly detailed as well
