Newly acquired!davey0555 wrote:Hi Colin,
First time I have seen this thread, never knew you had a mk2, well done mate, it looks great!
Dave
ColinJack wrote:Right - couple of questions.
Firstly - anybody got a suitable bonnet release cable for Baz ... 1980 Mk2 Custom
Also, Baz has a low mileage Pinto engine. I found a bottle of additive in the van which would suggest it hasn't been modified to run on unleaded. I obviously want to keep the engine, what is the best way forward?
Excellent! Anyone able to provide the necessary info? Colindieselhead123 wrote:ColinJack wrote:Right - couple of questions.
I am sure I read on here that some of the later 202/205 heads are unleaded, I am sure I remember the post saying that there were letters cast into the head to identify them.
I have a couple of later 202/205 heads in stock, if a fellow member could clarify the identification markings, I could sort a head out for you while Baz is with us.
Thanks. I will rub some rust off to see what I haveKerryB wrote:Haynes manual for 86-89 petrol has:
1.6 litre. A, K, M or MM
2.0 litre. A, L, P or PP
This is stamped on the cylinder head adjacent to No. 4 spark plug.
burtonpower.com have sohc pinto engines
1.6 litre. M, MM or N, NN
1.8 litre. S, SS
2.0 litre. P, PP or R, RR
I hope I have this right and it helps you out.
Okay - great! I will do some research to see where our nearest is. Thanks.bambi mk 1 wrote:Colin you could get a cable made.Try Cablecraft.ie.I have used them loads of times and very reasonable and they may have a branch over your side.
