The inner rear cross member is now in place so time to repair the floor area, left side was straight forward;
The three holes are where the pillar support panel bolts on.
Next job was to fabricate an inner rear corner panel for the right hand side;
This was made up of a number of parts then welded together so we could install it as one piece. Holes were punched around the edges where 'plunge' welding was necessary.
Then fitted to the van;
and welded in place.
Then we made a replacement channel section for the right rear spring hanger, when we cut the rear cross member out the roof dropped, the rusty outrigger was the culprit
Here we see the new part tacked in place;
and welded in;
