Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Postby AndyG » Mon May 08, 2006 12:50 pm
8) 8) 8) 8) 8)
Can't wait for the finish :!: HURRY UP :lol: :lol:
Postby MrMPuk » Mon May 08, 2006 12:52 pm
I don't think you can rush him! I think it will be worth the wait though.
Postby AndyG » Mon May 08, 2006 12:55 pm
MrMPuk wrote:I don't think you can rush him! I think it will be worth the wait though.
He needs egging on, and hopefully the paint has encouraged him to sacrifice other jobs and get on with the Tranny :wink:
Postby 24vMk2 » Mon May 08, 2006 1:41 pm
What spoiler is on the front Luke?
I wouldn't mind one of them! 8)
24vMk2
Postby stevew » Mon May 08, 2006 2:18 pm
Looking good! 8) 8)
Can't wait for the final result now :P
Steve
Van Cam, service suspended (no van!) (no cam either!)
stevew
Postby Luke » Mon May 08, 2006 7:52 pm
thanks for the comments guys :D
the flatness of the panels is down to steve! we're very pleased with the finish there are a few areas we would have spent a bit more time on to get them "perfect" but actually getting time to spend on the van is allways a struggle! and the van will be used (not abused) ................... one day :lol:
24vMk2 wrote:What spoiler is on the front Luke?
got it off martinjpainter - he was going to use it on his busbut decided against it!!! :D
Postby Andrew-v4 » Tue May 09, 2006 4:31 pm
Looking good luke, what engine's going in? A lovely v8 :lol:
Andrew-v4
Postby Luke » Tue May 09, 2006 7:13 pm
Andrew-v8 wrote:Looking good luke, what engine's going in? A lovely v8 :lol:
nah :( just a 24V cossy :wink: keepin it pinto for a bit tho, till i sort the interior!!! :D
paint
Postby Steve@CCR » Tue May 09, 2006 10:21 pm
i'd also like to thank the members for their comments.
luke chose a great colour.
a few areas will need a bit more minor work, but they will
be done after the van is back on the road.
Steve@CCR
Postby Luke » Sun May 14, 2006 7:28 pm
Got her sitting on all 4 alloys today 8) looks great but i wish now i'd gone for a higher profile tyre, the ones i have are 225/50 R16 on the back and 205/55 R16's on the front :!: i chose them as they were the same diameter as the 185R14C's that were on before but I think when they wear out i'll swap em for 225/55 R16's and 205/60 R16's - i just think they will suit it better!!! 8)
also the van sits really high :shock: - dont know why at the back, there's no reason - infact it should be lower as ive removed the rasing blocks that were there :? - im hoping it will settle down a bit once its been driven :?
but the front sits higher as ive removed the Di :D - i think i may have a set of knackered leaf springs to fit in the front to lower it tempararly till i fit the ifs :D
Postby Gunslinger » Sun May 14, 2006 8:18 pm
lol .... like that ...re-use the knackered springs !
will those raiser blocks fit my mk2 ? :wink:
Gunslinger
Postby Luke » Thu Jun 08, 2006 10:54 pm
fitted the diff input shaft seal today :D
got it from JimH - thanks mate :!:
had a little trouble trying to knock it in :x anyone whos ever fitted a core plug knows the feeling :lol: so i made this puller contraption the pipe fits over the outer edge of the seal and the plate goes over the top then the diff flange nut holds it in place, a combination of pressure applied by the nut and tapping the plate with the hammer gets it in a treat :D
apart from that im still on with the rear disk conversion- hopefully i'll have it all done this weekend!!! :D the rear axle :!: not the van :lol:
Postby Luke » Sun Jun 11, 2006 6:24 pm
Update- Got the engine running today :D - i'd had it running before i started but i think all the petrol must have evaporated away :? so i stuck a pipe into a bottle of petrol stood on the floor - unfortunatly cos of this i couldnt drive anyware but i'll pop up in the week with some fresh petrol and have a run around :lol: one thing i did find was the carb gasket is leaking :( i'll have to sort that before the test :)
also i had a look for some of the bits missing to complete - bits of trim etc. but nothing to stop me MOT'ing her :D
Postby FredTransit » Mon Jun 12, 2006 12:06 pm
Luke wrote:Update- Got the engine running today :D - i'd had it running before i started but i think all the petrol must have evaporated away :? so i stuck a pipe into a bottle of petrol stood on the floor - unfortunatly cos of this i couldnt drive anyware but i'll pop up in the week with some fresh petrol and have a run around :lol: one thing i did find was the carb gasket is leaking :( i'll have to sort that before the test :)
Getting close now! :D
FredTransit
Mk2 Trannyist
Postby madmark » Mon Jun 12, 2006 4:32 pm
:shock: gaydon here we come then mate! :?: :wink: :wink:
