mk5 transit recovery wrote:looked under it mate as had 2 take prop off b4 it could be moved as was all jumping about.
carnt see why box failed? its split in half across ways & has also split bellhouseing in half near starter moter.
needs :
mt75 box
clutch
flywheel (ring gear fooked)
starter (maybe)
gave it 2 a local garage who supplying & fitting all above for £240!!!! not worth doin it myself 4 that price
sorry for the 2 replies, only saw the last one in the window when i came into the thread at first.
the damage to the box (ie splitting in half) is making you wonder if something broke, jammed up and then caused the box to grenade itself, right? well very hard to determine if something inside caused the destruction, Especially as you were doing 80 at the time, if the box cracked around the bell housing and then seperated at an angle, it would probably cause enough of a problem to effectively seize up, reversing the normal power transfer from the engine to the back wheels, to the wheels and forward motion (plus the vehicle weight) trying to drive the engine through the gearbox, if it seized up in the clutch area (or g/box side of clutch) i could well beleive the forces involved caused the internals of the box to be forced apart, fracturing an already damaged casing past the point of its strength
