Couple of pics of the drive flanges with the wheel bearings still in place, Transit one on the left'
Note the similar fixing method, bearing housing to swivel.
Now, the outer part of the D3 bearing housing is too large to fit in the Transit swivel and the bolt pattern is wrong, so the simplest method is to remove the D3 wheel bearing and housing and fit a Transit bearing to it. Couple of pics of both the drive flanges with the bearings removed for comparison, Transit on the left;
Now here is the first 'problem';
The D3 drive flange has a raised lip on the end, (highlighted in RED)this needs to be carfully machined off to enable the Transit wheel bearing assembly to be fitted, watch this space!
