3244
Re: 3244
Postby andz327 » Mon Apr 27, 2020 10:06 am
Can you gas weld oxy/acetylene ?? If your a half decent gas welder you'll pick up tig no problem,
Can you get gas refills ordered through BAM , these fookin hobby weld gas bottles are nightmare oxy/Acetylene dont last long and need air products oxy filled
ANDZ
andz327
Re: 3244
Postby Airthies » Mon Apr 27, 2020 9:39 pm
andz327 wrote:Can you gas weld oxy/acetylene ?? If your a half decent gas welder you'll pick up tig no problem,
ANDZ
I'd steer clear of oxy/ace getting refills is a farce.
Boc now own all bottles and you hire them per year and they all have serial numbers which are on the hire sheet so practically impossible to swap old bottles you've got yourself nowadays.
Think most of the big suppliers are the same, but depending on what your doing just use propane. Hobyweld do bigger bottles, than just the dinky ones.
Acetylene is only required for really hot flames, for welding etc. Propane is fine for heating and burning.
Years since I did gaswelding but used to enjoy it.
Nearly pressed the button on a new tig today but bottled out think I'll sit down tonight later or tomorrow and do it... I've pretty much convinced myself it's a toy I will need.
Sorry "tool" I will need!
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby loot » Mon Apr 27, 2020 10:52 pm
Get some cans of spesh down you, you'll sober up and in a well you'll wonder why there's an all singing all dancing welding machine on special trolley being delivered as if by magic :lol: then a sharp pain to the heed off the mrs possibly :shock: :lol:
Ids map here
loot
Re: 3244
Postby Airthies » Mon Apr 27, 2020 11:31 pm
loot wrote:Get some cans of spesh down you, you'll sober up and in a week you'll wonder why there's an all singing all dancing welding machine on special trolley being delivered as if by magic then a sharp pain to the heed off the mrs possibly :shock:
It's workshop equipment, business cost
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby loot » Tue Apr 28, 2020 8:17 am
There you are, a legitimate business expense 8) puntos fiesta is a legitimate business expense too, it is for team building and wellness. 8) :lol:
It's not what you say its how you say it :P
My lair is a panic room :lol:
Ids map here
loot
Re: 3244
Postby Cosworth63 » Tue Apr 28, 2020 10:24 am
Not been on here long but if I may offer some advice reference tig welding.With the tig welding you refer too 1/2”plate.The 160 will probably struggle too get a pool going because of the massive heat soak effect.Having used both owning both rtech and parweld tigs I would say rtech the better to deal with and after sales service second too none.Hope I am not trying too teach you something you already know but I have been a welder/fabricator for 35 years.Paul.
Cosworth63
Re: 3244
Postby Punto443 » Tue Apr 28, 2020 10:59 am
The xr2 is for advertising, the xr3i is a quick response vehicle, jimny for winter and rough terrain call outs,
All parts are maintainence and training :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: 3244
Postby Airthies » Tue Apr 28, 2020 5:01 pm
Cosworth63 wrote:Not been on here long but if I may offer some advice reference tig welding.With the tig welding you refer too 1/2”plate.The 160 will probably struggle too get a pool going because of the massive heat soak effect.Having used both owning both rtech and parweld tigs I would say rtech the better to deal with and after sales service second too none.Hope I am not trying too teach you something you already know but I have been a welder/fabricator for 35 years.Paul.
Cheers Paul, I'm happy to have any info on many things. Every day's a school day an aw that!
I'm a plant/agri fitter (currently taking out broken exhaust studs on a Porsche with my wee ark inverter, for my mate) but do my fair share of welding but Tig's not something I've dabbled with, I did plenty gas welding years ago before MIGs became commonplace, well for the mob I worked for at the time anyway
I might hit you up for some tips once I get going, as ordered a R-Tech TIG201 AC/DC this morning and a starter pack of rods which I reckon should keep me going for a while.
Stay tuned for the inevitable carnage
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby ned » Tue Apr 28, 2020 5:24 pm
That's cheating, you have a ramp :lol: are the studs coming out easy?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: 3244
Postby Airthies » Tue Apr 28, 2020 6:28 pm
ned wrote:That's cheating, you have a ramp are the studs coming out easy?
Not my ramps but the place that I do use ramps when required it was already up in the air when I got there.
And No! They're being barstewards, but they're not winning the fight
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby Cosworth63 » Tue Apr 28, 2020 6:36 pm
If I can help in any way please ask.If you haven’t done tig for a while practice on mild steel.Always remember that you are welding reverse polarity(work to torch not torch too work) and keep the tungsten sharp.Rtech used too have some really good videos and there tech help is good.Got one of those welders(5 years old and no issues).Paul.
Cosworth63
Re: 3244
Postby Airthies » Tue Apr 28, 2020 7:02 pm
Cosworth63 wrote:If I can help in any way please ask.If you haven’t done tig for a while practice on mild steel.Always remember that you are welding reverse polarity(work to torch not torch too work) and keep the tungsten sharp.Rtech used too have some really good videos and there tech help is good.Got one of those welders(5 years old and no issues).Paul.
Yes they seem to have a decent reputation amongst the guys I've talked to, not heard much bad about them, think I've seen one gripe about their machine being noisy, and another about 7.5% discount being abit rubbish
And I can see a spewtoobe session happening tonight
Got one bolt left to get out so should have that done by the delivery arrives and can start playing. As it's being delivered to my mates workshop allegedly tomorrow
Got a couple of hobyweld bottles this morning, one argoshield, one argon.
Just need the twat in the unit next door to move out so can get in and sort out this new lair and get going on the projects.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby Cosworth63 » Tue Apr 28, 2020 8:25 pm
Any tig welding is argon pure only no matter what you are welding.I have dealt with them for years and they are very ‘frugal’ on discounts. :D
Cosworth63
Re: 3244
Postby Airthies » Tue Apr 28, 2020 9:29 pm
Cosworth63 wrote:Any tig welding is argon pure only no matter what you are welding.I have dealt with them for years and they are very ‘frugal’ on discounts. :D
Yea the argoshield is for the MIG tired of using the stick at home for wee jobs or borrowing a bottle if I've got lots to do and if I'm getting one I might as well get two
Most of the stuff I do for work is petrol mosa geni/welder or customers MIG in their workshop.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby Airthies » Mon May 04, 2020 12:31 am
Finally got the flairs on, not too bad I think, would of been happier I think if they didn't curve down as much but came out more straight. But beggers can't be choosers apparently when your paying a premium
Only took 1 na' ½ in the end to get it all done.
.... will add pics from web upload as craptalk says I've uploaded too much already this month
V86+patch
V86.04
X-Prog
C81
Airthies
