Think Your Dads is 25/26 Miles Per Gallon is about right (if I've converted it from metric ok
pg125 wrote:once you have carried out the conversion to the bosch 145 pump do you leave the original low pressure fuel lift pump on and working as in still supplying fuel to the injection pump ?
sparxmetalworks wrote:Hello, I have recently replaced the epic pump on my MK5 1999 county van with the 686-2 Bosch pump and i am having problems getting the van to run properly again I have read as much as i can find about it on here but dont know what to do, can anyone help or suggest anything to try.
I have now got it done and everything assembled and have also managed to bleed it through and get it running but unfortunately i dont think it running on all cylinders and when i give it acceleration theres hardly any power there and cuts out when i let it off.
I before i put it all back together i checked the timing many times but cranking the engine round by hand and fitting all the pins back in successfully every time.
I am pretty sure i have got all the air out the fuel system, the solenoid is definitely getting power and the pump and fuel filter have fuel.
I am at a total dead end with what to try next.
Would massively appreciate any help as am getting frustrated looking at my van doing nothing.
thanks,
sam
