Today I got the selector fitted not as bad as it looks position wise but need to drive it and see if it needs extending!
Also got prop done today,most outlay upto date-£120!! but it's all balanced,new C/bearing and I know it won't split in half!
The gear linkage is a right pain,done around 4 prototypes and I still think I've got to use a cable,Ho hum!
Now don't laugh but I need a oil cooler for the box and after chatting to Rover I need a huge one!(especially in Spain!) so I thought of using a Condenser!-loads more fliud capacity,made for higher pressure than the auto will push out and can be mounted in front of the rad with the fan on that,any thoughts?
Ah!-almost forgot,a little tip, got the p/steering pipe fitted today,you can use the Scorpio one with a bit of tweaking!
