'TRANSCORPIO'- 1974 LWB MK1/1994 2.9V6 Scorpio crossbreed
Re: 'TRANSCORPIO'- 1974 LWB MK1/1994 2.9V6 Scorpio crossbreed
Postby barabas » Sun Jul 05, 2009 10:06 am
Absolutely cracking work there, thanks for sharing and keep it up! 8)
The two most common elements in the universe are hydrogen and stupidity.
barabas
Postby madmark » Sun Jul 05, 2009 12:28 pm
8) 8) keep it up mate ! :wink:
Postby cartooner » Mon Jul 06, 2009 5:45 pm
Thx for the support guys.
Now I had welded the head of the Scorpio steering colomn onto the Mk1 outershaft. Still it would be very comfortable if the steering wheel could come a little closer to the driver. This would give more distance between the steering wheel and dashboard too. Luckily I had a spare
steering box and shaft from the Mk1 I had scrapped. I decided to lenghten both the innershaft and the outershaft with 4 inches(10 cm) of material taken from the spare box.
I cut both innershafts and tapered them with a grinder. Then I welded the V-shaped joint, grounded down the weld and welded it again. For extra strength I also welded up a sleeve to the shaft at the spot of the joint. This 'sleeve' is originaly screwed to the shaft and acts as the steering lock. It is no longer needed, since I have the Scorpio steering lock now.
and here is the lenghtened innershaft:
Now I removed the bracket from the lenghtened outershaft and welded it back on 4 inches lower down. So here's the altered outershaft:
cartooner
Postby cartooner » Mon Jul 06, 2009 5:59 pm
:D Now finally, all was ready to bolt the dash in for the last time. I still have to finish it, but sofar the result is pretty satisfying. All the original Scorpio switches, stalks and lights work. I only had to put the throttle pedal a tad more towards the brake pedal and place it at a slighlty different angle for comfort. I used a stainless gardenfence hinge :shock: :lol: as a base fo the
pedal, like this:
And here is how the dash looks. Like I said I have still some finishing to do. You will also notice that the dash is not wide enough for the MK1, but that was very handy after all, because the main fusebox sits in that space on the passenger side:
Scorpio stalks are a bit short compared to the large Mk1 wheel, but I can live with that.
and
I'm pretty satisfied with the results sofar, but have one sane advice: Kids, please don't try this at home! :lol:
cartooner
Postby MattBlackMinibus » Mon Jul 06, 2009 6:10 pm
cartooner wrote:I'm pretty satisfied with the results sofar
Mate, so would I be :!: Quality job 8) 8)
Starting All Over Again
MattBlackMinibus
Postby Row1 » Fri Jul 24, 2009 5:55 pm
Jos, what did the propshaft modification cost, if I may ask?
About your car: Mooi werk! ;-)
Row1
Postby ake » Fri Jul 24, 2009 6:07 pm
Thats seriously cool 8) 8) 8)
Postby cartooner » Fri Jul 24, 2009 7:13 pm
Row1 wrote:Jos, what did the propshaft modification cost, if I may ask?
Lengthening it with 55cm ( like I said they had to use a thicker/wider tube), including balancing cost me 150 euro. Without a bill that is, if you know what I mean.
cartooner
Postby bezzabsa » Fri Jul 24, 2009 11:15 pm
Excellent work - took some guts to do the dash mod.
Driving a Transit estate...Mondeo 130 Tdci 2002 ;)
Yam Yam from yamyam land ayit ??
Bostin' ay it?
bezzabsa
Postby Runna » Sat Jul 25, 2009 12:26 am
excelent work there mate, you have some skills.
Runna
MK6 Transit Faster than a smack heads giro! :D
Runna
Postby Neil » Sat Jul 25, 2009 4:56 pm
luv that dash nice job :!:
Neil v6
Neil
Postby AlanN » Sat Jul 25, 2009 5:40 pm
Great idea, dash looks really good :D
Postby irishtransit » Sat Jul 25, 2009 5:57 pm
looks very modern from the inside.nice job
irishtransit
Postby cartooner » Sat Jul 25, 2009 8:09 pm
Thx, everyone your feedback is appreciated :wink: !
cartooner
Postby oldskooler » Mon Jul 27, 2009 12:58 am
awesome thread this, top work there. well done.
oldskooler
