Finally some nice weather on Sunday, ideal for those roof sealing tasks.
As i said previously i needed to seal the join between the alu roof and the fibreglass roof. I got a flap wheel on the grinder and removed all the old resin deposits and rubbed down the roof ready for the stick on flashing i bought.
It was easy to apply just peel the backing off and stick, rolling it as you went with a wallpaper seam roller, perfect!
Next was the old flue for the Electrolux heater.
Again i used the leisure battery box of the carvan and cut a section out to patch over the hole.
Stuck that down with mastic.
I decided the gas boiler flue i did last week would be better sealed for the future with the stick on flashing, and i will do the same with the other patch next week.
The rest of my time was dismantling the caravan, ive got the gally out now and the overhead lockers and got the thetford toilet out. you can see that the caravan was really damp on the back wall and when i pulled the wall lining it looked just like the camper when i started...Rotten
