Back in Essex now, after a fekin baking day. Van drives sweet, pulls great and the noise has died down on the timing gear
only down side seem to have slight fuelling issue with the fuel pump, might need a space in between pump and block? doesnt seem to be getting full stroke on the arm of pump, but pumped manually is fine! emptied the fliat chambers pretty fast on the a2
Anyone confirm if there should be a spacer between pump and block? cheers!
Other than that im well chuffed with my new exhaust note, more power and prob more top end (but carb needs tweaking at some point) and once i sort the fuel pump its gonna kick ass!
