Adam 120 ex aa's new transit mk1 project
Re: Adam 120 ex aa's new transit mk1 project
Postby Adam mk1 » Mon Jun 21, 2021 7:58 pm
Been a while thought I'd do a bit on the mk1
I'm doing gearbox crossmember I've turned around one end of mk5 auto crossmember both sides
Also putting captive nuts in chassis with reinforced plates pictures hopefully will explain the rest
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Postby Adam mk1 » Mon Jun 21, 2021 8:04 pm
Adam mk1
Postby Adam mk1 » Mon Jun 21, 2021 8:05 pm
Adam mk1
Postby Adam mk1 » Mon Jun 21, 2021 8:07 pm
Adam mk1
Postby Adam mk1 » Mon Jun 21, 2021 8:08 pm
Adam mk1
Postby Adam mk1 » Mon Jun 21, 2021 10:45 pm
Adam mk1
Postby Adam mk1 » Mon Jun 21, 2021 10:46 pm
Righthand inline with panel
Adam mk1
Postby Adam mk1 » Mon Jun 21, 2021 10:48 pm
Adam mk1
Both bolts line up so it's square
Adam mk1
Postby MinorMatt » Tue Jun 22, 2021 9:49 am
Can't believe you've touched it!
Postby Adam mk1 » Tue Jun 22, 2021 2:12 pm
Yep all welded last night just grind the welds off and gearbox crossmember will be bolted up tonight
So that's engine & gearbox mounts done
Also been doing a bit on tailgate alignment before I do back panel,
Also ground off welds on nearside rear arch
Adam mk1
Postby Adam mk1 » Tue Jun 22, 2021 4:47 pm
Adam mk1
Postby Adam mk1 » Tue Jun 22, 2021 4:49 pm
Adam mk1
Postby Adam mk1 » Tue Jun 22, 2021 4:50 pm
Adam mk1
Postby Adam mk1 » Tue Jun 22, 2021 4:51 pm
Adam mk1
