BROWNYS V6 MK3
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Fri Dec 08, 2017 11:15 pm
so I went from a quick rub down and repaint, to bare metal the bugger, dress the welds and a quick etch prime for now till I decide on a colour, new discs turned up today aswell.
next step, wheel and the shafts off the the machine shop for a trim off the spigot rings as the wheels wont fit on the shafts, on the lookout for a 3.9 cwp if anyones got one
cheers.
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Sun Dec 10, 2017 3:50 pm
forgot to mention, got me front arches aswell, why is it, panel suppliers have started coating repair panels in galv, not lookin forward to fitting them at all, might have to attack them with the sand blaster first, welding galv coated panels is gonna be proper sh*t :evil:
was gonna get the van out today, but in all this snow it will just rust away faster
bugger :roll:
BROWNYS V6
Re: BROWNYS V6 MK3
Postby Tiago Camilo Jorge » Tue Dec 12, 2017 3:03 am
BROWNYS V6 wrote:hi tiago
the wheels on my van were chrome weller wheels, the front are 6 inches wide, 14 inch diameter and the rears are 7 inches wide and 14 inches in diameter, the front tyres are 185 55 14 and on the rear they are 225 40 14. the chrome had gone rusty so I cleaned then up primered them with 2 pack and painted them black.
cheers
browny.
Hello again!!
I buy these wheels but the rear wheel is to bigger, so the sliding side door hits on the tire.
What is the ET of your rims?
look the Pictures...
TiagoCamiloJorge
Tiago Camilo Jorge
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Wed Dec 13, 2017 12:25 am
hi mate, your van is a mk4/5 mine is a mk3, there is a difference in rear axle widths, yours has the wider one, what size are your rear tyres?
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Sun Dec 17, 2017 10:43 pm
so i have dropped off my bits at the machine shop for a bit of a shave, and today ive been playing with my new air filter, had a rusty old pancake thing on it for years, junked the mesh and sponge ages ago and sealed it up and fitted a cold air tube, but now i have this
still need to cut a hole in the side for the cold air pipe to feed it, still cant bring meself to cut the wings and arches off, who knows what im gonna find
more soon.
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Thu Dec 21, 2017 8:28 pm
chop chop :shock:
more soon.
BROWNYS V6
Re: BROWNYS V6 MK3
Postby g-man » Thu Dec 21, 2017 11:01 pm
luvin the bertie 8)
g-man
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Fri Dec 22, 2017 10:56 pm
cheers chap :)
been a busy boy today, more choppin and welding, not as rusty as I thought it was gonna be on the inner wheel arch bit
more soon :)
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Sat Dec 23, 2017 11:04 pm
bit slow today, managed to get the arch fitted, and chopped the wing off the nearside
more soon.
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Wed Dec 27, 2017 11:10 pm
back in rusty transit mode, the red oxide and the grey paint I used on the offside reacted with each other and went soft, so I had to thinners it off and start again :roll:
so I mixed up some epoxy primer and brushed it on
cut the arch off the other side,inners are rustier than the offside
removed the leisure battery tray to clean up underneath it
found a hole in the spring hanger, so made a repair to that aswell
more soon.
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Sat Dec 30, 2017 10:26 am
more choppin an welding
more soon.
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Sun Dec 31, 2017 6:56 pm
my new wings had some surface rust on them, so got the da out with some 80 grit discs and bare metaled both of them, then gave the a blast with the grit blaster then another go with the da, then primed them up with 2k epoxy primer
managed to get the wing fitted today so its lookin van like again, also a while ago I fitted Subaru front seats, at the time I also got the rear seat and removed the cover with the idea that we would use it to recover the double seat that's in the back of the van so they all match, tracy the trimmer has made a start over the last couple of days
takes ages just strippin the old covers off, and taking the Subaru cover apart so it can be assembled to fit the transit seat, its getting there, cheers wifey
more soon.
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Thu Jan 04, 2018 11:06 pm
got the wing fitted, and wifey is crackin on with the seat re trim 8)
had to smear a bit of filler round the arch to iron out some mole grip marks, got a small dent to fill in the wing too, but its getting there
more soon :)
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Mon Jan 08, 2018 11:17 pm
wow 1500 page views since I started my makeover and only one reply, must be some sort of record :) hey ho, had a busy weekend
needs a skim of filler round the arch, got a couple of other bits to do on the rear arches aswell and I might fix the dent in the side door
more soon :)
BROWNYS V6
Re: BROWNYS V6 MK3
Postby dirtydog » Mon Jan 08, 2018 11:20 pm
BROWNYS V6 wrote:wow 1500 page views since I started my makeover and only one reply, must be some sort of record :) hey ho, had a busy weekend
We're all just too busy looking at the pictures :wink:
dirtydog
