Adam 120 ex aa's new transit mk1 project
Re: Adam 120 ex aa's new transit mk1 project
Postby Adam mk1 » Tue Aug 01, 2023 9:00 pm
Yes please matt, I'm not close enough yet to pre fit it yet mind, but when I am if you could that would be great, thanks again for offer, and obviously il pay for your time, thanks
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Postby Adam mk1 » Tue Aug 01, 2023 9:05 pm
Adam mk1
Postby Adam mk1 » Tue Aug 01, 2023 9:08 pm
It's easy, so that one plugs in there, then that one over there, hang that ones upside down, then this one, shut up will you now I've lost what I was doing gotta start again
Adam mk1
Postby Adam mk1 » Sun Aug 20, 2023 2:48 am
Ive done a walk around video of my mk1 transit on YouTube channel is called, wolls woyce gawage, if that doesn't find it put in mk1 transit listed in the last week and im sure you can find it, cheers Adam
Adam mk1
Postby Neil » Wed Aug 23, 2023 7:17 am
does fitting the modern diesel lose its mot exemption ?
Neil v6
Neil
Postby Adam mk1 » Mon Aug 28, 2023 1:42 am
Neil wrote:does fitting the modern diesel lose its mot exemption ?
Fitting different engines loose there MOT exemption
Unless it was an engine regularly used 30 year's ago
So you should be OK with your unique
2500cc rover V8 engine
Adam mk1
Postby Adam mk1 » Mon Aug 28, 2023 1:47 am
Is it bronze
Adam mk1
Postby Neil » Mon Aug 28, 2023 8:42 am
its red now , but i will update my logbook if it makes you happy :roll: by the way i looked at the youtube vids your making a right proper job of it :? :?
Neil v6
Neil
Postby oldskooler » Wed Sep 13, 2023 3:12 am
just checked out the vids on youtube....really shows the amount of graft and effort going into this project...
was good to chat at beaulieu mate...keep up the good work... 8) 8)
oldskooler
Postby MinorMatt » Wed Sep 13, 2023 3:39 pm
Its not whether the engine was in use 30 years ago its whether it was fitted 30 or more years ago.
"Engine
Alternative cubic capacities of the same basic engine and alternative original equipment engines are not considered to be a substantial change.
If the number of cylinders in an engine is different from the original it’s likely to be, but not necessarily, the case that the current engine is not alternative original equipment." On that basis, as the Di was never fitted to the mk1 - so I think you've lost your MOT exemption.
However there is also a statement in the guidance
"It does not count as a ‘substantial change’ if:
they are changes of a type which can be demonstrated to have been made when vehicles of the type were in production or within 10 years of the end of production"
I'm fairly sure early 2.5Di from Mk2s would have been fitted in mk1s within 10 years of the mk1 going out of production. I think you are probably fairly safe to say its MOT exempt - but you will need evidence of mk1s being converted to 2.5Di before 1987 (which shouldn't be too hard!)
Postby Adam mk1 » Fri May 10, 2024 11:23 pm
Let Me post
Adam mk1
Postby Adam mk1 » Fri May 10, 2024 11:34 pm
Ooh I can post cool
Thanks Neil for positive comments
Thanks old schooler I don't remember talking to you at beaulie
I must be getting older
Thanks minor Matt for your detailed explanation and help
It's not a problem il just bung a well known transit mk1 owner who has a name that's sounds a bit Like bee a few quid and we're say no More
About it
Also Matt I'm stil going to want your talent's
Please to try and make Me a stunt loom
Adam mk1
Postby Neil » Sun May 12, 2024 9:53 am
any updates adam ?
Neil v6
Neil
Postby Adam mk1 » Sun May 12, 2024 4:37 pm
No more progress yet Neil but should do a bit next couple weeks
Adam mk1
Postby Adam mk1 » Tue May 14, 2024 6:28 pm
Adam mk1 wrote:No more progress yet Neil but should do a bit next couple weeks
I did put a disc brake front axle in it the other day
Adam mk1
