Bryan wrote:The weather's held ok today so I took the opportunity to weld the front crossmember in position. I will have to make up a new cover for the chassis on the driver's side.
Running low on welding gas already.... the size Y bottle is nearly empty already and I only got a few months ago.
I've also made a start on the rear axle. The mounts will have to be cut off and moved inboard slightly and then welded back on again.
Bryan wrote:It is indeed... I'm hoping to get some use out of it before the end of the summer so I'm trying to get something done every time I get a chance. Plus it's payday again so whether the wife likes it or not I'll be ordering more parts![]()
It'll be nowhere near as good as your MK3 though!
