Trimmed replacement down to size
Offered up to check fitment before welding into place tomorrow
tourneo newbie wrote:How are you going to get round the abs on the mk7 axle I've been told it won't work on the mk6?
tourneo newbie wrote:What if you put it on a mk6 that does have abs will it still be ok or will the brakes not work
Brains_transit wrote:Coming along nicely
paul2012 wrote:tourneo newbie wrote:What if you put it on a mk6 that does have abs will it still be ok or will the brakes not work
Brakes will still work.
Although may end up with ABS light on. Not sure on that one. Never done one on a mk6 with ABS.
It will be something I can easily sort, even if it means retro fitting mk6 ABS ring & sensor onto mk7 hubs
tourneo newbie wrote:paul2012 wrote:tourneo newbie wrote:What if you put it on a mk6 that does have abs will it still be ok or will the brakes not work
I've got abs light on at mo anyway lol due to a broken front wire so not fussed about that I've been offered a mk7 rear axle that's been redrilled to fit bmw wheels so just wanted to make sure it would be ok
tourneo newbie wrote:Bmw wheels will be fine there off an x5 so there load rated
