My mk5 smiley V6 Jag engined van
Re: My mk5 smiley V6 Jag engined van
Postby robbie.cee » Sun Sep 06, 2015 10:35 pm
Use jag back axel and use abs sensor to drive speedo directly!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby MinorMatt » Mon Sep 07, 2015 9:08 am
Or just use the transit speedo...
Postby Pocketrocket » Mon Sep 07, 2015 1:13 pm
robbie.cee wrote:Use jag back axel and use abs sensor to drive speedo directly!
MinorMatt wrote:Or just use the transit speedo...
The jag has an independent rear end so using the axle isn't an option, and as for the dash/clusters i could use mondeo clocks and do away with the jag ones (but wheres the fun in that!) :lol:
Im assuming the speedo on yours robbie is driven from a sensor on the gear box? The jag may well be the same as it does have a speed sensor on the gearbox but whether this is enough for the the speedo to run on were not quite sure yet :?
1991 mk3 2.5di county 4x4 lwb ex mini bus camper conversion
1999 mk5 tourneo (previously jagvan, now Vw PD powered now with new owner :cry: )
2000 mk5 with a jaguar twist :wink: (now dead but will live on)
1996 disco 300tdi 1.2 offroad toy :D
Pocketrocket
Postby robbie.cee » Mon Sep 07, 2015 7:25 pm
If its three wires its a squarewave generator...makes pulses for speedo... could prob make the abs happy too
and i bet the jag diff is better ratio too
Had
MAKE IT FIT
robbie.cee
Postby Pocketrocket » Mon Sep 14, 2015 10:03 pm
Got myself some rear seats for the van, leather scienic seats for the massive amount of............ £10! :D
Now to find some for the front :lol: (dog checking them out too)
Pocketrocket
Postby DodgeRover » Tue Sep 15, 2015 5:45 pm
Are they seperate? Looks like if they are they might work quite well as a front seat.
DodgeRover
Postby Pocketrocket » Wed Sep 16, 2015 11:13 am
DodgeRover wrote:Are they seperate? Looks like if they are they might work quite well as a front seat.
Yeh they are 3 separate individual seats, im on the look out for a couple of range rover classic/p38 seats in grey, they also have the armrest too
Pocketrocket
Postby Pocketrocket » Tue Dec 08, 2015 11:32 am
Hey all just thought id refresh this thread as ive not up dated it for a while, well there ist much to update you all on with regards to the van, I haven't done anything with it as ive been ploughing throug the jag to get to the looms etc..........there is just so much bloody car to go through!
The interior is out and most of the dash is out just got to remove the main part of the dash so I can then get to the ecus, once thats out we can start thining the wiring out and isolating the engine ecu.
Sorry there isn't much to report after such a long time but its still an ongoing thing and will keep you updated when somthing interesting happens ;)
Pocketrocket
Postby DodgeRover » Sun Dec 13, 2015 9:06 pm
Is the jag still running in full power mode? I hope you are keeping a list of what wires go and what stays...
DodgeRover
Postby DodgeRover » Thu Dec 17, 2015 8:13 pm
@pocketrocket does your jag have the VVT on it?
DodgeRover
Postby Pocketrocket » Fri Dec 18, 2015 6:58 pm
DodgeRover wrote:Is the jag still running in full power mode? I hope you are keeping a list of what wires go and what stays...
Yes its still running/driving no loss of power (can still get it sideways lol) the abs is disconnected which in turn knocks the speedo off too as it runs off the abs sensors and 1 on the gearbox (we think it calculates an average speed from the 5 sensors) the aircon is disabled as is most of the dash.
DodgeRover wrote:@pocketrocket does your jag have the VVT on it?
Yes it does, so 240bhp (well probs lost a few ponys over the years) but we'll see if we can up it a bit with de-cats and a good service etc......
Pocketrocket
Postby DodgeRover » Sat Dec 19, 2015 5:10 pm
Thats encouraging, what happens if you disconnect the instrument cluster?
DodgeRover
Postby Pocketrocket » Mon Jan 04, 2016 7:41 pm
DodgeRover wrote:Thats encouraging, what happens if you disconnect the instrument cluster?
Sorry for the late reply, the cars at work so no been touched all over the xmas break, will be dismantling majority of the dash tomorrow night, ive been reliably informed that the cluster can be unplugged an plugged back in without any problems, its when a new cluster is introduced the problems arise as it needs to be paired up at jaguar.............but ill find out tommorw :D
Pocketrocket
Postby dieselhead123 » Mon Jan 04, 2016 8:08 pm
Hi there, my preliminary research suggests that disconnecting the cluster will interupt the 'start curcuit', but have a go and test this. If you find this to be the case I can PM you what I believe to be an immobiliser 'by-pass', be interesting to find out if it 'works' :wink:
Postby robbie.cee » Mon Jan 04, 2016 9:24 pm
Next project Tim, jaguar v6 to mt75!
Had
MAKE IT FIT
robbie.cee
