Mk1 LWB Ex-Feuerwehr Camper Conversion
Re: Mk1 LWB Ex-Feuerwehr Camper Conversion
Postby Luke » Thu Feb 19, 2009 9:25 pm
bit of an update
ive cut the ply for the base for sophie's bed - it's 6mm ply but i'll screw some battings across to give it a bit more strength :D i'm also going to make it removable, as it make the storage area more usefull! i'll fit some clamps from underneith that hold the bed in place when the van is moving :D
after that i fitted a side panel, it's ply again but i'm hopeing to get some sort of adhesive covering for it to make it look nice :lol: im sure you can get something :? :lol:
the roof looks tricky to do so i'm leaving it till last :lol: i'm gonna do each bit of the roof seperate - the bit above the bed i might make a bit lower and fit more insulation above there :idea:
i've also made the front panel but no pics - i made it in one piece but i'm not sure i'll not need to cut it in half to fit it in :o :lol:
Postby Luke » Fri Feb 20, 2009 2:01 pm
more pics :lol: so easy to post when the van is being worked on outside the house :D
this shows again how much storage there is 8) and also why i'm converting to single rear wheel to get rid of the massive inner arches :)
one more from the front - between the 2 skins will be a storage tray for books, phone torch etc. accessed from the bed :D
Postby AlanN » Fri Feb 20, 2009 5:04 pm
What sort of covering are you looking at, vinyl, carpet, both need glue... I tried stick-on vinyl film, but it fell off in hot weather :(
If you want to curve the ply around the roof, then buy a few sheets of flexi-ply to do the corners, its only a couple of mm thick, but you can build up 2 or 3 layers, then carry on along the roof with standard stuff.
Postby Anton2k3 » Fri Feb 20, 2009 5:29 pm
Looking good! Just a quick note about sticking stuff to you and AlanN, when i re-did our roof lining in faux suede, I used copydex. It didnt soak through the material, and gives a very strong bond. Its latex based, so you put a coating on both surfaces, let it go tacky, then bang them together. Stays flexible, and fine in hot weather etc.
Ta,
Anton
Anton2k3
Postby Luke » Fri Feb 20, 2009 6:30 pm
thanks for the advice - i'll have a look at those products 8) i'd actually not thought of carpeting round the bed area :idea:
what sort of radius will flexi-ply bend to :?:
Postby AlanN » Fri Feb 20, 2009 6:45 pm
it will bend into a 3" circle, had to pin it down and glue with evostick, the thicker ones will bend to about 6", but you only need 2 layers for about 8mm ply and as strong as hell
Postby belly » Fri Feb 20, 2009 7:43 pm
single wheels!!! :shock: :cry: and theres me trying to find a drw van :( i can see why though those arches do look like they take up a lot of space :? lovely van luke doing a nice job 8) how about some epoxy flooring resin adhesive for sticking stuff ? i was also going to suggest bendy ply for the roof :)
belly
Kaiser Chief
Postby MR BigBeefy LDV Guru » Fri Feb 20, 2009 11:11 pm
just a silly q luke
could you not just fit only one wheel on then cut the arch out is there a reason why you cant :?: :?: :?:
Transit dreamer!
Postby Luke » Fri Feb 20, 2009 11:16 pm
i'm gonna fit a mk4 single wheel axle, it's wider than a mk1 axle so the wheels will be right outside the body and into the arches 8)
if i just took the inner wheels off it would put extra wear on the bearings plus the ratio is bad :(
Postby MR BigBeefy LDV Guru » Sat Feb 21, 2009 12:15 am
Luke wrote:i'm gonna fit a mk4 single wheel axle, it's wider than a mk1 axle so the wheels will be right outside the body and into the arches 8)
ok so if some one was tofit wide wheels that would overcome the bearings prob yes ???
sorry to hijack the thread
Transit dreamer!
Postby Luke » Sat Feb 21, 2009 12:18 am
wide wheels will always put more wear on the bearings but taking one wheel off will shift the force too far over to 1 side it will put extra strain on - ideally you want the centre of the tyre under the centre of the bearing, and fitting a mk4 axle moves the bearings out further :D
Postby DOL » Sun Feb 22, 2009 5:11 pm
looking good m8 :D just a q shudnt these old vans be kept standard :?
Image 1 by 1 the penguins keep stealing my sanity!!
DOL
Formerly known as Dafodol.
Postby Luke » Sun Feb 22, 2009 6:36 pm
cheers :D
DOL wrote:just a q shudnt these old vans be kept standard :?
what as fire engines :shock: the way i look at it is this van wouldn't be here unless i brought it over :D in Germany these vans are quite common and not particuarly cherished :(
The only way i was gonna bring one over is as a camper conversion project, i have no need for a fire engine :lol:
personally i like to see them done back as vans like the one geoff did but as i allready have 2 vans i dont want to do that to it either :lol:
mabe one day it will be returned to a van but for now it's going camping :mrgreen:
Postby DOL » Sun Feb 22, 2009 6:52 pm
no i didnt mean as a fire engine m8 that would be daft :D i was referring to the back axle swap,imo the vans look better as twin wheelers :D the camper conversion is a great thing to do to it luke as the van has to b practical(espically when you`ve got a family) is was just really asking about the exterior,like you say there better converted back to a van :Di should have explained myself more luke sorry :wink: :D
DOL
Postby Luke » Sun Feb 22, 2009 7:07 pm
i think they look great as twin wheelers too but the inner arches are just way too much in the way :( also it gives me a good ratio as a single wheel axle which is a big bonus :D it could be converted back to twin wheels in years to come as all i'll be altering is the inner arches they could easly be refabricated all the alterations to the mounting points will all be done on the axle (i'll cover that on this thread when i do it) :D
and they can look good as single rear wheelers :mrgreen: 8) :mrgreen:
and even tyres as fat as that gives loads more space in the back :D
