mk4 swb semi transit gone !!! :)
Re: mk4 swb semi intys89 2nd project update! fitted cd player!
Postby intransit89 » Fri Oct 31, 2008 10:44 pm
MR BigBeefy LDV Guru wrote:it matters because thats the law if you have an accident and kill someone then you will go to jail for a very long time
yes i know :wink:
intransit89
Postby MR BigBeefy LDV Guru » Fri Oct 31, 2008 10:48 pm
so its not clever is it
at best if they see you driving they will crush the van and give you a massive fine
Transit dreamer!
Postby intransit89 » Fri Oct 31, 2008 10:54 pm
got the log book today so gona sorn as soon as by phone as internet is fooked as my last one was the orange one and it wasnt sorn so dont trust the internet one
:wink:
only 5 owners too :D
intransit89
Postby MrMPuk » Sat Nov 01, 2008 3:12 am
What a total numb nut!!! We knew that though didn't we.
Postby intransit89 » Sat Nov 01, 2008 1:17 pm
got my new transit badge today for this van for the back door for when i have tidyed them up and resprayed them 8)
intransit89
Postby intransit89 » Sun Nov 02, 2008 4:12 pm
bad point and good point of geting this one done is
start with the good ones,
got two new rear arches
got some steel thats new from work for the floor and welding the inner wings up.
got some wheel trims coming to tidy it up
take the floor up and clean to bare white paint and spray back stone chip on to stop it rotting
take the back drivers side wood sheet to push a dint out on the back window panel
got some 2k white do to the back doors and back wheel archs and front bonnet and grill thats that done
bad points
got a shed load of crap in it at mo due to mate moved just down before cleethorpes
no gas and knacked spray gun :lol:
intransit89
Postby intransit89 » Fri Nov 07, 2008 9:39 pm
today i got a set of wheel trims some plastic filler and some plastic primer
oh and painted the transit rims mat black :wink:
intransit89
Re: mk4 swb semi intys89 2nd project!doing grill and got wheels
Postby intransit89 » Sat Nov 08, 2008 6:24 pm
to dayswork 8)
intransit89
Re: mk4 swb semi intys89 got smoke inds badboy bonnet and grill!
Postby intransit89 » Fri Nov 14, 2008 12:09 am
right then on this one iam doing a other badboy bonnet ie the white one that was on it i been hiting the edge of the steel where its got a 2cm bend so its bend over back on to the steel thats the edge as i rember guy88 saying its need to be like this so you dont cut your head open i did this with the red bonnet too thats going back on the orange one when i finshs this red one in primer and painted in orange :D
tomorow night iam browing the markita metal electic cutter from to cut my steel to shape ready to weld them on the white bonnet for next week evenings to pass time on as its dark when i come home from work
the plan is to keep the orange painted bonnet for a recovery ie if the bonnet fails mot on the orange one so i have a normal one to put back on haha
intransit89
Postby intransit89 » Fri Nov 14, 2008 12:50 am
oh and forgot this i got from ford
for the white van when the back doors are in new paint 2k dimond white 8)
should finsh the job nicely when the back archers are on to :)
intransit89
Re: mk4 swb semi intys89 new transit badge!!!
Postby bigmastif » Fri Nov 14, 2008 3:56 am
rob like i said on the other thread GET ON WITH IT
just dont turn this van and thread into another 100+ page thread and drama :lol: :lol:
bigmastif
Postby intransit89 » Fri Nov 14, 2008 6:51 pm
bigmastif wrote:rob like i said on the other thread GET ON WITH IT
i am i got my back drums of the orange one to night :lol: tock 10 mins each with the crow bar but i need some shoes but the drums are ok good as new also i need them springy bits for the brakes as thay broken when i tock the drums of with the shoes so now iam gona order some new brake shoes and them springy bits and a new hand brake cable
looks like i just sort the cable by undoing the theaded bar till thay tenched up? :idea:
intransit89
Postby MinorMatt » Fri Nov 14, 2008 8:06 pm
springy bits = fitting kit ;)
Postby gazza » Fri Nov 14, 2008 8:59 pm
you most likely ripped the retaining clip off cos you didnt wind the hand brake off, or release the auto brake lining adjuster. a lip will have formed on the drum, snagged on the shoes and then bust the retaining clip.
before you refit the drums it is a good idea to remove the lip from the drum. this can be done with a grinder, but you must be careful and not stray onto the working face of the drum. the corrct way to skim a drum is to put it up in a lathe, but for god sake dont attempt it yourself..............
gazza
Postby gazza » Fri Nov 14, 2008 9:07 pm
btw, i agree with you about the cost of industrial gasses. i use a 10l beverage co2 cylinder at a rental cost of £5.69 per 3 months including VAT. refill is a tenner. i have not had a refill in a couple of years.................BOC for a size Y argosheild (argon/co2 - the correct one!!) - about 4 times bigger cylinder is 62 quid + vat. refill is arround 40 odd quid. you should not be using as much gas as you do.
you need a flow meter set to arround 8 - 10 litres per minute, check all your connections with soapy water.
gazza
