few jobs on my mk2 swb, turbo di and pas conversion etc.
Re: few jobs on my mk2 swb, pas conversion etc.
Postby madmark » Fri Jan 08, 2010 2:51 pm
mate she sits in there so nice 8) i dont think you will even know you have a trailer on the back with that engine :wink:
Postby oldskooler » Sat Jan 09, 2010 12:19 am
madmark wrote:mate she sits in there so nice 8) i dont think you will even know you have a trailer on the back with that engine :wink:
cheers mark, cant wait to drive it! :D
oldskooler
Postby imustloverust » Sat Jan 09, 2010 12:29 am
Wow you're flyin it! If i were doing that job there'd be more head scratching than engine swapping! :lol:
imustloverust
Postby oldskooler » Sat Jan 09, 2010 10:30 pm
i got a nice bit of work done today, very enjoyable doing the final fitting up because theres progress to be seen after a few hours! started by fitting up the power steering pump and pipes, then got the airbox mounted and finally got the rad fitted. front panel is now back on and i ran her for a good while this eve after filling up with coolant....no leaks yet thankfully!!
some pics.
starting with the pump.
i found a nice bit of stainless to make a resevoir bracket! 8)
airbox in place.
fixed pas return pipe to the back of the crossmember.
front panel on for good this time!!
used front panel to mount pas feed hose.
header tank bracket and throttle cable mounted.
top rad mounts.
bay more or less finished.
i fitted this main fuse holder from the mk5 to power the starting relay which ill fit inside. ill also have a spare power feed should i need it again.
not long now!!! :D
oldskooler
Postby madmark » Sun Jan 10, 2010 1:55 am
:shock: wow that looks so nice :wink: when you out on a test run??????
Postby oldskooler » Sun Jan 10, 2010 10:23 am
madmark wrote::shock: wow that looks so nice :wink: when you out on a test run??????
ive the propshaft sent away for shortening and balancing. im using the complete swb mk5 prop with the rear section shortened and have to make a pickup bracket for the mk5 carrier. would have been easier to use the rear half of the mk2 and mod the front section but the mk2 uj,s are a lot smaller. i think the full mk5 setup ill be a better job considering how much towing the van does.
soon as it comes back ill be away for a spin!!! :D
oldskooler
Postby madmark » Sun Jan 10, 2010 5:06 pm
i think it will be a great towing van ,when i had the 85ps turbo mk5 it towed so well ,so the 100ps should pull lovely and still give good mpg! :wink:
Postby davev6newman » Sun Jan 10, 2010 6:31 pm
i took the tank out of the mk2 di scrapper and was amazed by how much smaller it was than the tank in mine. so i just swapped over the gauge unit over into my own tank so id have the return pipe catered for and refitted the tank.
My van has got the small tank, i was wondering if there was any particular model that had the larger tank and bottom outlet like yours i should be looking out for, so i can swap. I was under the impression that all short wheelbased vans had the small tank?
davev6newman
Postby oldskooler » Mon Jan 11, 2010 7:56 pm
davev6newman wrote:i took the tank out of the mk2 di scrapper and was amazed by how much smaller it was than the tank in mine. so i just swapped over the gauge unit over into my own tank so id have the return pipe catered for and refitted the tank.
not sure mate, the large one appears to be the original in my van, who knows,....maybe someone was tinkering before me!! :D
oldskooler
Postby madmark » Mon Jan 11, 2010 10:04 pm
normaly transit swb had the small tank and the lwb had the 68ltr tank,i dont think it was a option to have the 68ltr on a swb but i am not 100% shure ! :?
Postby davev6newman » Tue Jan 12, 2010 10:12 pm
I had a mk1 shortwheel base camper and i could get over 60 quid of fuel in that and that was nearly 10 years ago, so that must have had a larger tank in it. It must have been an option. The Mk1 was a 2.0 V4.
davev6newman
Re: few jobs on my mk2 swb, turbo di and pas conversion etc.
Postby oldskooler » Fri Jan 15, 2010 12:26 am
ive been away from this project for the last few days working. so i got stuck in again this evening.
after more thought about what to do with the gearlever gaitor i decided to fit the mk5 gaitor and retaining piece. it was tempting to fit the floor section from the mk5 section as luke recommended but seeing as my floor mat is in mint nick i left my own floor in place and went a different way bout it.
i got the mk5 plastic flange ( gaitor fits over it) and sized it up. old gearstick hole needed to be blanked.
i ran out of 1.2 mm sheet so i went for some quality material!!! :D :mrgreen:
fitting nicely.
fitted and trimmed the mat to fit.
next i cut another piece of transit and flushed it into the original gaitor trim! i trimmed it to fit around the mk5 flange.
this covered the old hole in the rubber mat, some may say it looks stupid but i dont think it looks too bad!!
another small thought............where does the lever come through the floor on an auto :?: :?: couple of inches to the right would be lucky if the mk5 gaitor covered the mk2 mat!!!
i put the chair in to try the new lever position, real nice especially with the extension piece that came on the van, gives it the retro touch!!
i wont have the shortened prop back for a couple of days yet so i started to tackle another job i was dreading at the back. the chassis was a bit suss looking behind the shock mounts on both sides and after some hammering and cleaning i found some more work!!
left side.
right side not as bad.
so ive some cuttin and welding to do, your work is never done with theese vans!!! :D
oldskooler
Postby Luke » Fri Jan 15, 2010 12:35 am
yeah new stick gator dont look too bad :D shame about the rear chassis but its not a difficult bit :) bang some waxoil in there when you've welded it :!: :!: i did the whole chassis on mine once i'd done welding :D
Postby madmark » Fri Jan 15, 2010 12:57 am
for her age she is a cracker,love the exteshion on the mt75 stick that will make it realy comphy 8) 8) 8) 8) that van will fly :wink: with 4.1 and 5 speed i can see it sitting very happy at 90mph :shock: :shock:
Postby oldskooler » Fri Jan 15, 2010 1:12 am
Luke wrote:yeah new stick gator dont look too bad :D shame about the rear chassis but its not a difficult bit :) bang some waxoil in there when you've welded it :!: :!: i did the whole chassis on mine once i'd done welding :D
cheers luke, great minds think alike!! i got a loan of a wax gun and a couple of tins yesterday! i intend to have wax dripping out of her when shes done!! :lol:
will be glad to get the chassis sorted, shes very solid otherwise.
oldskooler
