mk1 1969
Re: mk1 1969
Postby roelsmits » Sat Dec 04, 2010 7:07 pm
madmark wrote:the word here is headlining :lol: :lol: you are dooing a great job and in the snow as well :shock:
the dutch word is just heaven (hemeltje) and this is no joke :!: :!: :roll: :lol:
roelsmits
Re: mk1 1969
Postby roelsmits » Sun Dec 12, 2010 1:08 pm
Hi all!
I have the windshield finally in, after 3 hours and 7 attempts it was in there in 10 minutes.
Normally you put the glass there with a rope but did not succeed, the window cleaved too much if you pulled the rope a third around :twisted:
That called for another approach with two ropes one above and one below in the middle and we started again, we`re ready within 10 minutes :lol:
(what a round window they dont make it this way anymore and I know why)
is there anyone with the same experience or was it my window :?: :?:
Roel
roelsmits
Re: mk1 1969
Postby madmark » Sun Dec 12, 2010 2:10 pm
well done ,at least you have the window in :wink: :wink:
in my mk1 the window was hard to replace but we got it there in the end ,and so far no leaks :wink:
Re: mk1 1969
Postby roelsmits » Sun Dec 12, 2010 3:42 pm
madmark wrote:well done ,at least you have the window in :wink: :wink:
it was so easy with two ropes I had to write about :D
did you use kit to seal it?
roelsmits
Re: mk1 1969
Postby roelsmits » Fri Dec 31, 2010 11:13 am
As I wrote earlier, I sat with my sliding windows,My frames were rotten and the rubber so dry that I've found another solution on
last two days at work was the CNC milling machine free (through the holidays)
so I used it Here a few pictures
the welding in the first picture is of my brother, I can not weld aluminum
a colleague took my camera
roelsmits
Re: mk1 1969
Postby madmark » Fri Dec 31, 2010 3:43 pm
:shock: wow very good work,this is a big problem with the slideing door transit,the frames allways rust! :wink: :wink:
Re: mk1 1969
Postby AlanN » Fri Dec 31, 2010 6:09 pm
Brilliant job youve done there. A few £ to be made there :wink:
Re: mk1 1969
Postby roelsmits » Sat Jan 01, 2011 12:41 pm
AlanN wrote:Brilliant job youve done there. A few £ to be made there :wink:
madmark wrote::shock: wow very good work,this is a big problem with the slideing door transit,the frames allways rust! :wink: :wink:
Thanks guys :)
It has cost me nothing just time, my boss has given the material and my brother did welding.
It took +-30 hours work but it does not matter.
I post a picture when it's done
a happy new year all :D
roelsmits
Re: mk1 1969
Postby Per Olav » Mon Jan 10, 2011 10:29 pm
Very nice work Roel.
Looks like it's going to be a beautiful van. :)
PO
Per Olav
Re: mk1 1969
Postby roelsmits » Mon Jan 24, 2011 7:26 am
Per Olav wrote:Very nice work Roel.
thank you
hi all.
I had been busy last week created new channel for the sliding doors and made bolts for the bumper (I had to grind them off by rust), paint the bumper bolts ent put it back on.
gr Roel
roelsmits
Re: mk1 1969
Postby Luke » Mon Jan 24, 2011 10:48 am
amazing engineering work 8) 8)
Re: mk1 1969
Postby tomboys3 » Mon Jan 24, 2011 12:24 pm
looks brilliant :D
tomboys3
Re: mk1 1969
Postby madmark » Mon Jan 24, 2011 2:27 pm
8) looking very good! :wink:
Re: mk1 1969
Postby roelsmits » Mon Jan 24, 2011 6:07 pm
thankx :)
roelsmits
Re: mk1 1969
Postby roelsmits » Sun Mar 13, 2011 10:53 am
I went for inspection last week.
failed on only two points :)
exhaust (but was worse as I thought so ordered a completely new one 365€ :( )
and rubber of drive shaft. ordered one by ford of a mk3 hope it's the same. :?
Everything comes in on Tuesday
gr Roel
roelsmits
