cossie7 wrote:Yeah mate got the right headgasket for it, the head should look new really it's only got 30k on it and been fully stripped cleaned and rebuilt!! Haha the pistons are quite a bit different to the 125 ones mate not even the rings are the same as i tried swapping them about on a spare St piston I bought.
Just a question when u rebuild them do you dial gauge the oil pump in or do it by eye?
cossie7 wrote:No mate according to ford data oil pump needs dialed in with a clock as it moves around 5mm on the bolts, thinkin about it there's no gasket on the oil pump as it wouldn't sit right if there was a gasket on it.
It's the later tdci mate it's a full 55reg St lump
Dint know quite what u mean about PCM? It'll be running full St management if I can get the clocks to work when I looked into it people reckon the clocks go cookoo? So don't know wether to use the 125 ecu and get it mapped but don't know if it will map aswell as the St one would?
Would you recommend having the injectors checked before fitting?
