belly wrote:Nice job as per usual
Tut tut though welding with your skin out
Wouldn't the bases benefit from a diagonal brace ? They look plenty meat enough just wondered about the twisting forces if you know what I mean
Id love to put some Focus st seats in mine but as a working van they wouldn't be very practical
I did think about braces, but decided against them because the square tubing is 2.5mm thick which is a bit of an overkill for the job it's doing. I'm quite confident in the welds too, 180A MIG on the highest setting and the steel was flowing well. If I'd gone for 1.5mm I would have put braces in. These are rock solid, absolutely no movement at all, I reckon they'd pull the 4 bolts through the floor before anything on the base gave
You could put some focus seats in then put seat covers on, but I guess that partially defeats the point of replacing the seats.
Yeah, I know about welding with exposed skin, when I had a small hand held mask a few years back,I had a band on my neck, it was it looked like I hadn't washed for ages. I should have put the sun block on before welding!
