Doing a great job as usual Tim
AlanN wrote:A few less spot welds will help keep the weight down![]()
KING OF ENGLAND wrote:Not to happy with that welding tim,more 1to1 lessons are needed me thinks
you did paint the inner panels first didn't you![]()
il tidy them welds up the weekend mate before people see them![]()
dieselhead123 wrote:Hi mate,
The lever that comes down from the guide pin is shaped differently, the main part protrudes into the pump body on the opposite side, so I was thinking about using the throttle lever that came with the pump top.
The type fitted with Manifold Pressure Compensators tend to have a 'spring' governor.
The 'Dodge' tuners, change the springs to alter max rpm, so I thought about using one from a 1.4 Fiat diesel, rpm limit being 5,400 or thereabouts.
I will have to get some pics up of the different undersides, camera on charge at the mo
knighty1981 wrote:have you thought about an oil cooler at all ?
I noticed all the marine ones have oil coolers on them.... looks easy enough to fit one... I've seen the same oil coolers on other things...
(the ones which screw onto the filter housing and then the filter screws onto it)
Guy88 wrote:knighty1981 wrote:have you thought about an oil cooler at all ?
all transit TD engines have them
knighty1981 wrote:going to look at a TD van to take the engine from tonight or tomorrow
IgorVigor wrote:Oil cooler is on the 'to get/fit' list for my transit......
The list keeps growing
Most important are some big injectors
