ITS GREEEEEN
Postby Sundowner » Sun May 13, 2007 10:36 pm
rover wrote:Thats a cracking piece of fabrication mate 8)
Rover.
I hope not :lol:
Sundowner
Postby Granadadriver » Wed May 16, 2007 8:26 pm
That's very good craftsmanship! 8)
Granadadriver
Postby Sundowner » Mon May 21, 2007 11:15 am
Started sheeting it out
the bracing is temporary
Sundowner
Postby Sundowner » Sun May 27, 2007 10:42 am
Engine cover is all done( appart from dynamat and carpet) finished all welding, removed the braces and all seals good, fits spot on and looks the part
Got these trick little latches from a boating supplier (not cheap) but they're adjustable and work great
Sprayed it with some metal surface sealer and thats it
Next thing will be stripping the bay reinforcing the front suspension mounts and fitting a later model brake booster/master cyl set up and then PAINT
Sundowner
Postby Luke » Sun May 27, 2007 10:58 am
Excellent work as usuall 8)
at the northern (uk) meet on the other side of the world :lol: we were talking about this van, and how impressed we all were with the quality of work you've done 8)
Postby Sundowner » Sun May 27, 2007 11:10 am
Oh WOW thats pretty damn cool :D
I just need the body to be as smick as your silver van and ill be happy
Sundowner
Postby Sundowner » Wed May 30, 2007 10:56 am
Like my big hole :lol:
Next time you see my big hole it should be all shiny green and new looking
Sundowner
Postby Sundowner » Sat Jun 02, 2007 10:51 am
Changed my brake booster and master cyl today
The booster/M cyl i used is from a 97 ford falcon i chose this unit as it has the right bore sizes to suit the transit 175 front calipers and the rear brake setup that im using it also has an internal poportioning valve and is cheap and easy to service
Fitting was fairly simple, I had to drill two new holes in the transit booster mount, change the flare nut on the rear brake pipe and extend the booster pushrod and change the end that fits to the brake pedal
Appart from some reshaping there was no other mods made to the front brake pipes
Thansit booster on left, the pushrod on the new booster was some 20mm shorter
Extended Pushrod with transit rod end, This was done by drilling a hole down the center of the new pushrod and tapping in a beheaded bolt and then tig welded into place
Doing it this way gives more strength than a but weld and wont snap under a heavy foot
Completed job, it took me about 3 hours to do this swap
Sundowner
Postby madmax » Wed Jun 20, 2007 9:28 am
Hey Sundowner, the MONSTER is getting there.. cant wait to see the 460 power house on the road.
Vanners Rock!
madmax
Postby Sundowner » Wed Jun 20, 2007 9:45 am
madmax wrote:Hey Sundowner, the MONSTER is getting there.. cant wait to see the 460 power house on the road.
Verrrrry slllloooooowwwwwlyyyyyyyy getting there
Just been playing around in the engine bay filling holes, bracing the suspension mounts and floor around the "engine hole" in preperation for paint
Stuck an EL falc wiper motor in required me drilling 4 holes and soldering 4 wires, I now have very fast wipers :D
So when are you fitting your lexus V8 :?: :lol:
Sundowner
Postby madmax » Wed Jun 20, 2007 10:00 am
ARE WELL??? will fit the 5ltr EL in around september at this stage i have to wait for my stepson to get holidays as hes my welder as i dont have the requiered skills ( if i do the welding the motor would fall out with in 50 ks ). and i also need to save up for the extras that will be needed.
Vanners Rock!
madmax
Postby Sundowner » Wed Jun 20, 2007 10:10 am
an old 302w??? oh well at least its a V8!
I thought you'd go for somthin a little fresh, out there and off the wall like the rest of the van
Sundowner
Postby madmax » Wed Jun 20, 2007 10:26 am
Na my beater got a 97 EL and has donated the motor, box, wiring & comp so how could i say no! the price is right ( free ). the only problem is the diff, mines a 5.16:1 geelong diffs are going to put a 9" center with 3.7:1 into my axle so then i can stay with the 6 studs & my rims, $2975.00 drive in drive away..
Vanners Rock!
madmax
Postby Sundowner » Wed Jun 20, 2007 10:48 pm
madmax wrote:Na my beater got a 97 EL and has donated the motor, box, wiring & comp so how could i say no! the price is right ( free ). the only problem is the diff, mines a 5.16:1 geelong diffs are going to put a 9" center with 3.7:1 into my axle so then i can stay with the 6 studs & my rims, $2975.00 drive in drive away..
Turf the comp and wiring the EL has a body control module and will be a real head f#*k to get working
Every thing like door locks wipers airbag and aircon are controled by it
Sundowner
Postby madmax » Thu Jun 21, 2007 12:38 am
thanks for that info, tho i have found a company in SA that make a plug or wire? unit that tells the comp its all ok.. found this threw Fordforums australia.
thanks again
Vanners Rock!
madmax
