Puk, a troublesome fairy!
Re: Puk, a troublesome fairy!
Postby RustWidow » Sat Sep 21, 2013 11:15 pm
So he's fixed at last?????
RustWidow
Postby jonochap » Sun Sep 22, 2013 12:01 am
I reckon :) can get to almost anywhere now :)
Owner of not so troubled puk :)
jonochap
Postby robbie.cee » Sun Sep 22, 2013 6:45 pm
See ya Tuesday then hopefully !
If that weller is up yours can ya bring it along pls
Ta
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby jonochap » Sun Sep 22, 2013 8:11 pm
Weller??? Sorry not yet...only just got moving yesterday! Trying to sort a kent meet at the moment but think i might need to confirm a couple of bits with the Muttster very soon...will keep you informed.
One thing that puzzles me though (ok, one in a number) there are 2 screws on the back of the weber. One on the back that controls tickover...turn clockwise til almost stall and back an 1/8th or so...but the other one is a mixture screw on the left back corner. Puk was making a lot of white smoke so i reduced the mix by turning clockwise but it went fully in. Is that right? Puk still runs but shouldnt this stop the fuel feed? Or is it there something else that gets mixed in?
jonochap
Postby robbie.cee » Sun Sep 22, 2013 8:55 pm
That's the mixture screw mate.
Usually fully un then back out a turn and a half.
In to lean out to entice mixture.
Too lean is no balls , backfire and tops out early.
Too rich is go like stink and stink s too and smoke...
Adjust 1/8 or 1/4 turn at a time!
I can double check the ignition timing for you Tuesday too , my pinto ran best at 6 degrees before tdc at idle !
Had
MAKE IT FIT
robbie.cee
Postby jonochap » Sun Sep 22, 2013 8:59 pm
Thanks robbiemate, that would be cool :) mutts did a brill job setting it but i havent forgotten this was your original :)
jonochap
Postby robbie.cee » Mon Sep 23, 2013 8:30 pm
LOL entice.... Enrich ...stupid phone!
My last post was altered by autocomplete...
Had
MAKE IT FIT
robbie.cee
Postby jonochap » Mon Sep 23, 2013 9:09 pm
Right, going in on the sopwith now, just to be sure we can get to robbiemates...fanks mutts, will let you know mission status later!
jonochap
Postby Muttley » Mon Sep 23, 2013 10:35 pm
Remember, idle screws (mixture and tick over) only effect idle. As soon as you come off idle the mixture goes through progression to main jets. This mixture can only be altered by changing jet sizes :wink: :)
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby jonochap » Mon Sep 23, 2013 11:24 pm
Wow, didnt know that. That makes a whole lot of sense. So the idle affects the smoothness of the run then and the timing affects the combustion...interesting...
Good news about the tracking ends though, means that robbiemates is so far so good :) if it happens then this will be the first essex meet me and puk have ever got to!
One other question...how do i stop the nuts on the outlet manifold to the exhaust working loos all the time?
jonochap
Postby Muttley » Tue Sep 24, 2013 8:33 pm
Use the correct locking type nuts :)
Muttley
Postby jonochap » Tue Sep 24, 2013 11:09 pm
Ah, right, so what, pray tell, should they be??? :)
jonochap
Postby jonochap » Tue Sep 24, 2013 11:17 pm
I can find m8 aerotight ss 13mm??? :)
jonochap
Postby robbie.cee » Wed Sep 25, 2013 7:42 am
Spring washers dude and or threadlock
Had
MAKE IT FIT
robbie.cee
Postby Muttley » Wed Sep 25, 2013 11:24 am
They are M10 x 1.25 locking nuts, NOT nyloc or they will melt, thread lock wont work either but double spring washers will :)
Muttley
