Its Lean, Its Mean, Its Green
Re: Lean Mean and going to be Green
Postby limitedblack » Sun Jun 16, 2013 7:59 am
That's the downside of modding, and of course the art of customising means all the really hard bits just look like they came from factory like that. Judging from your front bumper you won't have a problem modding the bulkhead. Get the hammer out :lol:
Happy Easter
limitedblack
Postby Luke » Sun Jun 16, 2013 8:08 am
AlanN wrote:Like Nick said, test fitting has thrown up some problems, starting with engine mounts (genuine Transit V6), which have support brackets to the gearbox, but the O/S one is in the way of the oil pipe that run up the side of the block. So we had a dig around the storeroom this evening and found some more Transit V6 parts, flywheel etc. and some mounts that don't have the arms on, so one of those was used, that problem sorted.
Adaptor plates made for the MT75, are in the way of the exhaust manifolds flanges, so looks like some custom ones will have to made...
Then the O/S rocker cover is very close to the bulkhead, then the top of the O/S exhaust is also touching and we haven't even tried the inlet yet :shock:
We have both had a look through some threads on here, but I'm still not sure how other members have got around these issues, some pointers would be appreciated :wink: -
i got round the mount by making a jig of the ford one and using it to make up my own
Postby AlanN » Sun Jun 16, 2013 11:24 am
We did think of notching the cast one or making a new one, do you think that support will be a problem if we use the one mount without.
Ive just had a message from NIck, who is at work now saying that he cant get the box in while attached to the BOB engine
Postby limitedblack » Sun Jun 16, 2013 11:35 am
Is the bob engine the last of the cosworth Cologne engines? I seem to remember that these where hard to defeat the immobiliser system on unlike the boa??? More power though I think.
Happy Easter
limitedblack
Postby AlanN » Sun Jun 16, 2013 11:42 am
It meant to be a stronger engine, people always seem to be scared of the BOB wiring, but we have a man who can :lol: thats the only reason Im saying that.
Postby limitedblack » Sun Jun 16, 2013 1:23 pm
AlanN wrote:It meant to be a stronger engine, people always seem to be scared of the BOB wiring, but we have a man who can :lol: thats the only reason Im saying that.
I had a mate who regularly put boa engines in different cars, but avoided bob because of the loom issues with the immobiliser, nice looking engines these, they fitted straight in the Sierra 4x4's shame ford never made them like that. These are a better engine as they got rid of the single camshaft chain, it was something silly like 9 foot long :roll:
Happy Easter
limitedblack
Postby fordboynick » Sun Jun 16, 2013 6:23 pm
I did get the engine and gearbox in today but the cylinder head is very close to the drivers side bulk head, so I will have to cut a little bit of the bulk head and re weld it and then smooth it off,i will get some pics as I go 8)
ive found a company that can make me a set of manifolds for about £450 which I didn't think was to bad :o
so once ive got the manifolds done and the bulk head just got to see if the power steering and alternator brackets fit as they look close to the chassi on the drivers side and then all I got to do then is wire it up which should be a doddle :D
Transit Customising and Restoration
All types of customising bodywork & welding undertaken in our fully equipt workshop. Big engine transplants
fordboynick
Registered Trader
Registered Trader
Postby fordboynick » Sun Jun 16, 2013 6:24 pm
no need to be scared of bob :lol: :lol: :lol: :lol: there not that bad
fordboynick
Registered Trader
Registered Trader
Postby robbie.cee » Mon Jun 17, 2013 3:02 pm
you wont believe how much metal i had to gring and belt sand off of the adaptor plate in mine, and the gearbox case to allow for the starter to fit!!! fekin hours!
good luck guys, youll sort it in the end... spare pair of hands here if need help with the looms... 8)
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby fordboynick » Tue Jun 18, 2013 6:20 pm
Well I got a bit done today :)
Cut away at the bulk head to make way for the cylinder head
Then started to shape some metal :D and weld
And then a little grind up to finish the welds off
fordboynick
Registered Trader
Registered Trader
Postby fordboynick » Tue Jun 18, 2013 6:29 pm
And the clearance is much better,hopefully finish the prep and get some paint in there :D
fordboynick
Registered Trader
Registered Trader
Postby madbri » Tue Jun 18, 2013 6:41 pm
is it on a roll over spit jig :roll:
madbri
Postby fordboynick » Tue Jun 18, 2013 6:44 pm
madbri wrote:is it on a roll over spit jig :roll:
No mate,I did the welding on the floor and then pushed it on the ramp to refit the engine :D
fordboynick
Registered Trader
Registered Trader
Postby madbri » Tue Jun 18, 2013 6:46 pm
:? ok u lying down taking photos :lol: how did u lower it? warm the springs up?
madbri
Postby BROWNYS V6 » Tue Jun 18, 2013 10:00 pm
nice bit of metal fab there 8)
BROWNYS V6
