Gaz's Mk3 truck
Re: Gaz's Mk3 truck
Postby BigMonty » Thu Apr 24, 2014 4:30 pm
great work 8)
Time is ticking thou :lol:
BigMonty
Re: Gaz's Mk3 truck
Postby Mr RVM » Fri Apr 25, 2014 1:23 am
BigMonty wrote:great work 8)
Don't I know it :(
Mr RVM
Re: Gaz's Mk3 truck
Postby Mr RVM » Fri Apr 25, 2014 1:40 am
Had to make a new "box" to replace the part of the chassis that the propshaft centre bearing is fastened to.....
Made it from 2mm steel and its going to be a fully closed box with a bolt on lid (so I can bolt bearing carrier thru the base then bolt lid on after) so it shouldn't catch water and road dirt and rot like the original setup.....
Should look ok once its painted :)
Mr RVM
Re: Gaz's Mk3 truck
Postby Mr RVM » Sat Apr 26, 2014 7:18 pm
A little bit done today (I'm on nights for the weekend so not a lot of time :( ) but got floor scrubbed, sealed and into primer
so from this.....
to this....
and this....
that used to look like this....
once I cut this bit out....
should get a bit more done tomorrow....maybe get doorsteps cleaned up and into primer.....we'll see... :lol:
Mr RVM
Re: Gaz's Mk3 truck
Postby Mr RVM » Mon Apr 28, 2014 10:30 pm
Well nothing done for the last 2 days as been just too tired after work to go up to farm and do anything so will be weds now (one of only about 24 full days left so will have to put a good day in) have managed to locate one of the rear panel end caps so just one more to find :) I'm down to my last litre of yellow paint (which wont go far) but found a local distributer (not cheap tho £60 for 5 litres :shock: ) to be fair tho some of the savings ive made on other stuff for this truck will pay for that many times over so not losing sleep over the price :)
should manage to get paint job started on chassis this week, getting that finished will be a real turning point (I think/hope) as it means I can start putting axle/suspension back in followed by front beam etc should see it ready to get it standing back on the floor on its wheels then it really will begin to look like a truck again :) :) :)
Mr RVM
Re: Gaz's Mk3 truck
Postby MinorMatt » Thu May 01, 2014 7:56 am
If it makes you feel better... the paint on Nadas green van cost nearly £400 for the 5L we used (including the activator etc)
Re: Gaz's Mk3 truck
Postby karl » Thu May 01, 2014 9:58 am
great work :D if it al goes right for me il have a mrk 2 in a few weeks :D
to start restoring to its original condition :D
karl
Tranny Lover!!!
Re: Gaz's Mk3 truck
Postby Mr RVM » Thu May 01, 2014 3:59 pm
MinorMatt wrote:If it makes you feel better... the paint on Nadas green van cost nearly £400 for the 5L we used (including the activator etc)
£400 :shock:
Cheers Matt that DOES make me feel a lot better :)
Mr RVM
Re: Gaz's Mk3 truck
Postby Mr RVM » Thu May 01, 2014 4:03 pm
karl mcghee wrote:great work :D if it al goes right for me il have a mrk 2 in a few weeks :D
Van or chassis cab :?:
Mr RVM
Re: Gaz's Mk3 truck
Postby Mr RVM » Thu May 01, 2014 9:27 pm
Just a few more pics of the latest brushwork :)
chassis where I rejoined it (joint is right thru the centre of the hole)
other side
doorsteps scrubbed and primed
and the other bits
finish work at lunchtime tomorrow and off sat so should get some more done over the next few days :)
Mr RVM
Re: Gaz's Mk3 truck
Postby Mr RVM » Sat May 03, 2014 8:23 pm
Well not as much work done today as I would have liked but happy with what has been done....First coat of paint on both steps and most of the rear chassis, and underneath the cab (from where gearbox crossmember fits to the back of the cab where chassis becomes "exposed") has been undersealed (everything was cleaned and primed before underseal was applied, not just covered over rust/crap) forgot to take camera so no pics but they wouldn't really show much anyway but hopefully next ones should :)
Mr RVM
Re: Gaz's Mk3 truck
Postby Mr RVM » Mon May 05, 2014 10:24 pm
Steps painted.....
Give the whole floor and the steps a coat of white paint first as when I did engine bay this turned out to be better than the yellow on top of the grey primer (should have used white primer :oops: ) but have plenty of white smooth hammerite so might as well get it used :!: (still think they need another coat tho) did the whole of the chassis in white too...
including the inside of the new centre bearing carrier box thingy....
splashed the last bit of yellow from the tin on a few bits......
and undersealed most of the underside of the cab....
back to work for 2 days now so back up on Thursday for some more...... :)
Mr RVM
Re: Gaz's Mk3 truck
Postby celtic0125 » Mon May 05, 2014 10:51 pm
Av u got any pics from b4 u started it mate
celtic0125
Re: Gaz's Mk3 truck
Postby Mr RVM » Mon May 05, 2014 11:04 pm
celtic0125 wrote:Av u got any pics from b4 u started it mate
You mean "as it was when I picked it up" :?: unfortunately I don't :( I rang the guy I got it from a while back to ask if he still had the ones he used on Ebay but he'd deleted them from his computer so there's none of it as it was then, only the ones from the start of this thread
It looked just like any old neglected transit....hand painted in green gloss paint that you could scrape of with your fingernails, sat quite straight and level (fook knows how :?: ) it was almost snapped in two :shock: (drove quite well too :?: :?: :?: )
Mr RVM
Re: Gaz's Mk3 truck
Postby celtic0125 » Tue May 06, 2014 8:27 am
Lol no worrys keep up the good work its looking good pal
celtic0125
