dieselhead123 wrote:Pocketrocket wrote:DodgeRover wrote:Thats encouraging, what happens if you disconnect the instrument cluster?
Sorry for the late reply, the cars at work so no been touched all over the xmas break, will be dismantling majority of the dash tomorrow night, ive been reliably informed that the cluster can be unplugged an plugged back in without any problems, its when a new cluster is introduced the problems arise as it needs to be paired up at jaguar.............but ill find out tommorw
Hi there, my preliminary research suggests that disconnecting the cluster will interupt the 'start curcuit', but have a go and test this. If you find this to be the case I can PM you what I believe to be an immobiliser 'by-pass', be interesting to find out if it 'works'![]()
Will do no problem, ive spoken to a few ecu specialists and they all say the immob cannot be deleted from the ecu via means of laptop etc etc but a by pass would be good as it will probably mean being able to get rid of the clocks (or instrumant pack as they call it)
