Red Ven
Re: Red Ven
Postby DG-Unit » Tue Feb 09, 2021 9:27 pm
Onto the chassis rail today...
Bit trickier in the end with wind blowing away the welding gas and all sorts of weird angles to get the torch in the right place but I’m happy with the weld quality. 2mm is much easier to work with than the 1mm I’ve mostly been using so far. After a vacuum down the rails I treated the whole area with rust converter and zinc primer. Used some cavity treatment spray further down the rails where I couldn’t reach.
2004 Transit SWB 85 T260
DG-Unit
Re: Red Ven
Postby Chug » Tue Feb 09, 2021 10:06 pm
Well done mate, I turned down my cousin when he asked the other week If I would weld his mk6 up becasuse of the cold etc, I spent most of December 2019 doing my mk4 :roll:
Chug
Re: Red Ven
Postby DG-Unit » Tue Feb 09, 2021 11:10 pm
Chug wrote:Well done mate, I turned down my cousin when he asked the other week If I would weld his mk6 up becasuse of the cold etc, I spent most of December 2019 doing my mk4 :roll:
I’d say that’s a good decision not to take that on. Double socks, double jumpers, thermals, 5 layers and in the south and I can’t manage it past 7pm :roll:
DG-Unit
Re: Red Ven
Postby ned » Wed Feb 10, 2021 4:06 pm
I tip my hat to you good sir, most people would have scrapped that van many welds ago, it’s nice to see you have saved the van and probably have a better van that’ll last you a long time, keep the up the good work.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Red Ven
Postby Nordic Blue » Wed Feb 10, 2021 5:49 pm
Still massively in awe of your determination and work DG-Unit. That is going to be one solid Transit soon!
I just took mine down to Lewes for a hospital thing and got a bit panicky passing the VOSA testing stop on the A23 (they were there today) as every time I go out to it there is more and more rust appearing on all 4 arches and the sills.
I really need to get mine looked at ASAP but was trying to wait for slightly better weather. This was to allow me to spend a few days trying to see what was surface and what was terminal rust and do a simple tidy up on the surface stuff myself to delay any major work. I now think I'm just going to have to bite the bullet and hand it straight over to a welder - especially after seeing what you've found - it is making me paranoid!
Mine is a white twin of yours - would be good to see them together when all this lockdown stuff ends at some point!
2009 Renault Trafic Sport Crew Cab
Vans I have also owned:
1982 MK 2 SWB Transit
1992 Fiat Ducato
1993 MK 4 SWB Transit
2005 MK 6 SWB T280 Transit
Nordic Blue
Re: Red Ven
Postby loot » Wed Feb 10, 2021 6:32 pm
Wait till you get the 10k electricity bill before you decide if it was worth it :lol:
I say this because I just got my bill since buying the lair and they want 100 quid /month on top of what I pay now to catch up with my usage :(
I used my sds chipper a lot to get concrete up and knock walls down etc, I also spent maybe 5 hours welding the van. Lights are all led so I hope that is cheap enough.
Ids map here
loot
Re: Red Ven
Postby DG-Unit » Wed Feb 10, 2021 11:12 pm
loot wrote:Wait till you get the 10k electricity bill before you decide if it was worth it :lol:
Ah yeah but LED lights don’t keep you and the environment warm like good old fashioned halogen. Luckily I’m using the electric supply at my work as I’m in their car park :D Replacing welding gas, gloves and flap discs is bad enough I can’t be doing with utility bills as well :lol:
DG-Unit
Re: Red Ven
Postby DG-Unit » Wed Feb 10, 2021 11:16 pm
ned wrote:I tip my hat to you good sir, most people would have scrapped that van many welds ago, it’s nice to see you have saved the van and probably have a better van that’ll last you a long time, keep the up the good work.
Thanks ned. Yeah it should’ve been scrapped but this is the kind of crap that happens in a triple national pandemic lockdown. I do hope it lasts a long time. All I’ve got to worry about after this is the actual mechanicals.
DG-Unit
Re: Red Ven
Postby DG-Unit » Wed Feb 10, 2021 11:40 pm
Nordic Blue wrote:Still massively in awe of your determination and work DG-Unit. That is going to be one solid Transit soon!
My Police friend said I should be worried by the VOSA test station as all the new welds might mean it's now over the weight limit :lol: I wouldn't worry too much about yours - mine was so bad because of all the bodge work. You just have to worry about Ford's OEM bodge work. Will be great to get vans together after all this. Any excuse to meet new people again and say "nah it's fine" at all the future MOT fails.
DG-Unit
Re: Red Ven
Postby DG-Unit » Thu Feb 11, 2021 9:11 pm
And finally on to the front...
DG-Unit
Re: Red Ven
Postby ned » Thu Feb 11, 2021 9:57 pm
What gas are you using? I use argon or argon/co2 mix and find I get less blow through, I’ll probably get told it’s the wrong gas but it works for me.
Are you fabricating the inner wings yourself? I need to replace a small section where the bumper mounts on the n/s
ned
Re: Red Ven
Postby DG-Unit » Thu Feb 11, 2021 11:24 pm
ned wrote:What gas are you using? I use argon or argon/co2 mix and find I get less blow through, I’ll probably get told it’s the wrong gas but it works for me.
Just using CO2 as it’s a bit cheaper. did use a bottle of argon mix ages ago but I wasn’t any good to know the difference. Main issue is my welder only has 4 heat settings so usually i’m going for good penetration and weld pool at
the expense of the odd blow through. Also hard at all these strange torch angles and tight spaces to make sure the tip distance is the same and you don’t hold it on that millisecond too long. Might try an argon next time for £3 more.
The wing on this side wasn’t too bad so I’ll probably just cut out the rusty part at the bottom
and fabricate that. I did want to buy repair panels as it’s just lest hassle but couldn’t afford £90 a go for the aprons and these were only half rusty.
DG-Unit
Re: Red Ven
Postby dumper » Thu Feb 11, 2021 11:29 pm
If you increase the wire speed slightly it can help reduce blow through
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Red Ven
Postby DG-Unit » Fri Feb 12, 2021 8:36 pm
dumper wrote:If you increase the wire speed slightly it can help reduce blow through
Notched it up a little today and did seem to be a bit better :D
DG-Unit
Re: Red Ven
Postby DG-Unit » Sat Feb 13, 2021 10:43 pm
Day 178
DG-Unit
