Red one
Re: Loots mk7 keeper
Postby blue estate » Thu Jun 13, 2024 5:19 am
loot wrote:This stuff?
Yep
blue estate
Postby loot » Thu Jun 13, 2024 10:47 am
I'll look into it cheers :D
Ids map here
loot
Postby loot » Thu Jun 13, 2024 10:59 pm
Fitted the crank seal to the timing cover then fitted the timing cover, the crank seal instructions are fit it dry :shock: I don't like that plan :x
I filled the engine with oil etc then thought I should probably replace the oil sump too and I can check the strainer :?
Ids map here
loot
Postby loot » Fri Jun 14, 2024 11:16 pm
Feel free to comment either way, my plan is to make it look modern not chav, this is just a dry fit it'll need painting etc. It looks modern and different and these are ford factory parts. :wink:
Ids map here
loot
Postby loot » Sat Jun 15, 2024 2:27 pm
Starts on the button,runs mint.
New rocker cover seal.
New injector seals.
New centrifugal oil filter.
New green o rings.
New copper washers.
Seats gently cut.
New oil
New oil cooler and filter upgraded metal screw type.
New vacuum pump gasket.
New fuel filter not fitted yet.
New timing cover and new crank seal.
New beru 11.5v glow plugs.
Injectors need programming in.
Fuel pump learn not done
Injector pilot learn not done
I did clean everything and removed it then refitted etc all pipes and wires checked and cleaned and tied up safely as it was new.
Took some cranking to pull the fuel through as I had the whole fuel system disconnected.
https://youtu.be/ieb7jaEN03E?feature=shared
Ids map here
loot
Postby ned » Sat Jun 15, 2024 2:53 pm
Interesting, difficult to tell how it looks without the wings n bonnet fitted, are the lights shaped to match the bumper shape?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Sat Jun 15, 2024 2:57 pm
ned wrote:Interesting, difficult to tell how it looks without the wings n bonnet fitted, are the lights shaped to match the bumper shape?
Yes hence me wanting to get it through mot. It looks a bit like a connect the more I look at it :lol:
Ids map here
loot
Postby loot » Mon Jun 17, 2024 4:59 pm
Can you believe the big ford badge I put away safely was still there, and furthermore I remembered where it was 8)
Ids map here
loot
Postby ned » Mon Jun 17, 2024 5:42 pm
I think it looks quite nice with the bonnet in place, how does it look with a wing on or do they need modifications to fit
ned
Postby loot » Mon Jun 17, 2024 9:28 pm
loot wrote:Can you believe the big ford badge I put away safely was still there, and furthermore I remembered where it was 8)
It's a ford bumper and headlights, I only need to remove the passenger tow eye bracket and I've bought a driver side tow bracket from Europe,I'll cut that off and weld a screw thread for a screw in tow loop. The 4 bumper bolts are slightly in different places but that's no problem. The wings will fit,I might need to make side brackets for them to connect the bumper but I expect the side screws will fit anyway. I need to paint the bumper, I need to turn the van around and do the drivers side replacement of the inner arches and sill etc line I did on the passenger side.
Lots left to do
Ids map here
loot
Postby loot » Tue Jun 18, 2024 2:49 pm
Despite the boys at ford trying to stop us from updating our tramps vans, I was able to get the cal!bration I needed and I updated my van f*** you Ford :P
Ids map here
loot
Postby loot » Tue Jul 02, 2024 10:36 pm
Bit more, drivers side front arch and inner arch removal and test fit.
Ids map here
loot
Postby loot » Tue Jul 02, 2024 10:39 pm
Might need to take the gearbox off :x any guesses why? :P
Least I can look at the clutch
Ids map here
loot
Postby loot » Tue Jul 09, 2024 10:24 pm
Bought 4 bb injectors that were sent for testing and tested ok,were still in sealed bags. £170 delivered. I need to do leak of tests on all of them etc.
Started doing a bit to the driver's side, was toying with the idea of plating the drivers side inner sill panel just so I can mot it and it'll give me a year to legally foof about with the van but after prodding at it enthusiastically it decided to remove itself. Don't really fancy buying a new panel knowing that I am going to fit a sliding door but also I don't want to remove the blank side panel in case I can't get the other bits I need to convert, what to do :|
Ids map here
loot
Postby loot » Tue Jul 09, 2024 10:26 pm
Been playing with my disks a lot and also playing with a lot of flaps 8)
Need this panel
Ids map here
loot
