Victoria Aust. 1980 van
Re: Victoria Aust. 1980 van
Postby deankdx » Tue Jul 26, 2011 10:57 am
Franfixit wrote:No Arachnid altercations for me....I just got inspired by the spiders in your Transit venting system to rework the classic 'redback on the toilet' seat song to suit your story...Victoria..Australia....I'm one of 'those' citizens who ran away to Queensland..so I understand the weather predicament.
I'll keep an eye out for when you're able to get back into it.
haha, didnt twig, needs a INSERT REDBACK TOILET SEAT SONG TUNE HERE Hint..
i still havent decided what dash to be used yet, on this van,.. i like the XE one i put up last, but the EA sports cluster is a close fit to the transit instument cowel. and i plan to use XF falcon or even fairlane wiring and hopefully get the cruise control working too.
its a bit adventurous, but should be doable.
1980 Mk2 4.1 litre 5 speed manual, 2.77 or 2.92 falcon diff conversion, falcon front discs.
project thread herer viewtopic.php?f=27&t=24731&start=60
deankdx
Postby Franfixit » Wed Aug 24, 2011 11:08 pm
deankdx wrote:haha, didnt twig, needs a INSERT REDBACK TOILET SEAT SONG TUNE HERE Hint..
I really have to remember to tick the 'notify when reply posted' box...Only just came across your reply when I noticed on your project link 'falcon diff conversion'...I went looking to see if you'd played that double long housing/axle game.It will be interesting to see the results of your dashboard mod, whichever way you go. Do you plan to hook up the falcon column by shortening the transit steering box column housing/shaft to somewhere near the firewall and linking them with a knuckle joint?.........or something more elaborate?
If you didn't build it yourself...It isn't really yours (Tim the Toolman Taylor)
Franfixit
Postby deankdx » Wed Aug 24, 2011 11:27 pm
i doubt i will modify it further now, it will probably end up with a cortina cluster in the stock dash with stock transit column.. mainly because i am on a time deadline with moving.
deankdx
Postby Franfixit » Tue Aug 30, 2011 10:30 am
deankdx wrote:i doubt i will modify it further now, it will probably end up with a cortina cluster in the stock dash with stock transit column.. mainly because i am on a time deadline with moving.
Last place we rented, the guy decided to sell the place..turned out better since the area we're in now is more rural...Every now and then I think..Hope something like that doesn't happen when the van is still a rolling shell/mass of spare parts.With the stock dash etc you'll be on the road a lot quicker and you can always mess with it down the line if you get bitten by the modification bug and time permits.
Franfixit
Postby deankdx » Fri Nov 04, 2011 3:45 am
well, continuing on my THINKING OUT LOUD ideas.
the XE dash cluster wasn't doing it for me, the dash needed a fair amount of modding to sit right i thought(i didn't think about chopping it to bits until after i butchered the XG falcon one)
i personally prefer the XG falcon setup anyway. i originally wanted to use the full crash pad, but the steel Transit dash would have needed too much cutting.
so i went to town on the XG dash with my Sawsall reciprocating saw.. what a brilliant invention
anyway, with this current setup, if i use a Full XF(not XG) wiring loom for engine bay and dash and modify the cluster wires to suit(done this before) and adapt the EB blinker/wiper combo wires it should be fairly easy to nut out.
**(i thought about using EB wiring as it will plug into the cluster and wiper thing.. but then the headlight and hazards will be not usable without mods on that side.. plus i already have an XF loom)
so, the EB blinker/wiper thing fits the transit column fairly close(needs a slight sleeve made up though) even the stock wheel cancels the blinker..
My thoughts are, get a Boss kit to suit the Transit and mount the XR6 momo steering wheel to that, i grabbed a horn ring off an EB fairmont for the cruise functions if i can adapt it to the transit boss kit properly?
anyway, had enough for today.. will do some more thinking to see if i come up with better ideas before pulling it all to bits to weld the rust up.
pics below are self explanatory pretty much
deankdx
Postby Franfixit » Fri Nov 04, 2011 4:57 am
deankdx wrote:I doubt i will modify it further now, it will probably end up with a cortina cluster in the stock dash with stock transit column.. mainly because i am on a time deadline with moving.
HA!...There is no hope for you!....the modification bug has bitten!....more deadly than any redback!! :lol: ...I'll come back for a better look at what you've done but right now I have to 'bail' to go to work.
Franfixit
Postby Luke » Fri Nov 04, 2011 11:05 pm
i'd like to fit a falcon XA or is it XB (we dont have them over here) dash to mine - i got the idea after seeing the interior shots of half breed :D
:arrow: viewtopic.php?f=17&t=82268
Postby deankdx » Sat Nov 05, 2011 12:19 am
Luke wrote:i'd like to fit a holden XA or is it XB (we dont have them over here) dash to mine - i got the idea after seeing the interior shots of half breed :D
yeah we dont have any XA or XB(same dash) parts here.. well not many at least. they are rare. i havent seen an XA-XB driving on the road for 10 years.
they all went the way of the crusher like the XF(1985-1993) falcons are now.. so little of them on the road the wreckers are scrapping them all.
even what i have fitted now is not really worth it in parts value.
see what happens, i am not committed to it yet, and may still change my mind and go back to the stock dash.
deankdx
Postby transitandy » Sun Nov 20, 2011 12:07 am
Very good thread m8y :) 8) 8)
Postby deankdx » Sun Nov 20, 2011 2:20 am
transitandy wrote:Very good thread m8y :) 8) 8)
thanks mate.
been thinking about it lately.. any day soon i will be back onto it one way or another(really need to adapt the combination switch wiring to the earlier falcon wiring first.
(can test that once done in my other car)
deankdx
Postby Franfixit » Thu Dec 01, 2011 9:08 am
That's some pretty interesting stuff you've got going with the dash....it'll all fit one way or another...depending on how you choose to skin the proverbial cat.
Love your magic dash mat....one size fits all.......you could put plates over those holes in the dash.....administer large quantities of selleys space invader....squish that dash mat down on top.......Voila!!!...One custom dash!!! :lol:
Franfixit
Postby deankdx » Thu Dec 01, 2011 9:58 am
Franfixit wrote:That's some pretty interesting stuff you've got going with the dash....it'll all fit one way or another...depending on how you choose to skin the proverbial cat.
actually, now you mention it, that space invader stuff shapes fairly well, could probably work it into a nice shape and skin it with vinyl if i am keen(doubt it)
been busy with other projects lately, will get there eventually. hopefully before the hot days come back
deankdx
Postby paul95mk2 » Fri Jan 27, 2012 1:19 pm
g'day i have the same transit as u but sliding doors ,chasing interior parts can u help?
paul95mk2
Postby deankdx » Sat Jan 28, 2012 12:42 am
paul95mk2 wrote:g'day i have the same transit as u but sliding doors ,chasing interior parts can u help?
where are you for starters?
what parts are you after? My transit has almost no transit parts in it..
deankdx
Postby paul95mk2 » Sat Jan 28, 2012 4:52 am
g'day from south australia, if you retention the spring in your indicator switch unit , remove left cover u will see the spring in the middle of the stalk switch play around with that,mine was the same ,took some fiddling but works
paul95mk2
