MK6 SWB Cosworth YB Conversion!
Re: MK6 SWB Cosworth YB Conversion!
Postby Luke » Sun Apr 13, 2008 4:58 pm
just got back - now have sump 8) :lol:
still raining a bit might get a bit more done :?
Postby rover » Sun Apr 13, 2008 6:16 pm
All be done by mid week then Luke :D
Cant wait to see this on the road :twisted:
Rover.
rover
Postby Ucof » Mon Apr 14, 2008 9:30 pm
Luke wrote:me and stu after a hard evenings graft :mrgreen:
I assume:
<-- You Stu -->
1991 MK3 SWB Low Roof 120 2.0Ltr Pinto (not for much longer :( )
Scientists have proven that the awesomeness of a forum thread is directly proportional to the number of pictures it contains.
Ucof
Powered by Nutella
Postby Luke » Mon Apr 14, 2008 9:47 pm
rover wrote:All be done by mid week then Luke :D
i have my target and i'm sticking to it :lol: :lol:
Ucof wrote:I assume:
<-- You Stu -->
yup, he's the one with the long hair :lol:
while i'm on ......... todays progress .......... I degreased the new sump and stu ordered a new complete clutch assy and a sump gasket set :D
he also went to fords and tried to get a fan cowl but they couldnt get a price as the reg no. didnt match :roll: see other post :D
Postby Luke » Fri Apr 18, 2008 8:48 pm
bit of progress today
got the engine and box back out
mounted the wireing
started swapping the sump and clutch
other things..... ford wont sell the cowl on its own £220 for it with the fans which we dont need :roll: and a similar price for a rad :shock: £70+vat is cheepest local so far :) and as the cowl isnt gonna hold us up it can wait for a bit :lol:
plan for this weekend is have the engine running :mrgreen:
Postby custom » Fri Apr 18, 2008 11:56 pm
good luck with it mate cant wait to hear this beast running whats happening with the body work and wheels/suspension?
custom
Postby rover » Sat Apr 19, 2008 8:23 am
Wonder why they wont sell the cowl on its own :? surely its better to make a small sale than no sale at all :?:
Rover.
rover
Postby Luke » Sat Apr 19, 2008 9:51 am
custom wrote:good luck with it mate cant wait to hear this beast running whats happening with the body work and wheels/suspension?
thats up to stu - its certanly getting a full respray but he's still undecided :D wheels will be alloys but again not made his mind up and the suspention needs to be dropped 6" to get in the garage so that will be done - the suspention brakes will all get sorted as we go along we're aiming for the ultimate mk6 8) aim high :lol:
rover wrote:Wonder why they wont sell the cowl on its own :? surely its better to make a small sale than no sale at all :?:
yeah you would think that - i bet the cowl gets damaged in accidents when the fans are fine - if there's anyone who knows another ford branch (we tried parkgate rotherham) that will sell it seperate let me know - other than that its breakers :D but the cowl wont stop it getting to north weald :lol:
Postby transitandy » Sat Apr 19, 2008 5:43 pm
looking very nice m8 8)
Postby Luke » Sat Apr 19, 2008 9:43 pm
Todays progress
new sump and clutch fitted - engine and box back in van 8)
thats the good bit :D - bad bit :( - the cossy starter wont fit :x close but no cigar :D its a bit annoying as were gonna have to try so start a fresh engine install by bump starting it :roll:
and we're hoping to have it started tomorrow :shock: if we get that done we should be on target and might have time to experiment with starters :D
Postby Luke » Sun Apr 20, 2008 7:47 pm
8) 8) 8) 8) 8) 8) 8) 8) SHE RUNS 8) 8) 8) 8) 8) 8) 8) 8)
Not without hassles tho :x :lol:
fellow forum member mk1 astra dave popped round this morning :D
haveing a look at the starter we decided it could be a rib in the gearbox casing stopping the starter going in so we pulled out the engine and box - split it and tried the starter without the engine attached :D
it wasnt the rib in the box :roll: but we did work out that the starter would fit on 1 bolt without the stone guard plate on :D
so back together without the plate and back in the van all wired up and just before we tried to crank it i manually turned the engine over and it wouldnt budge :shock:
the flywheel had gone back into the bellhousing :x
so we split it again and put washers inbetween to space it back - turned ok but ......... there was a banging that sounded like the crank hitting the sump :shock:
got a bit worried but realised it was the crank pulley triggers hitting the crank sensor mounting :lol: sorted that by grinding the edge off the nut :D
next wired it all up as much as we could mating between the 2 looms - got the starter solenoid to energise - so with the starter disconnected we energised the pinion lined it up with the flywheel and tightend the 1 bolt holding it on :o (will sort that later :P ) then as for some reason the fuel pump allready came on with the ignition we left it
then connected the perm live and the switched live to the cossy loom - thats really all there is to it :shock: anyone whos done a BOA loom could do a yb in their sleep :lol:
cranked it over with a screwdriver holding the starter still :lol: fired but wouldnt run :roll:
we then re-wired the fuel pump so it ran off the cossy loom as we suspected that it was cutting out when the pressure was lost, it was the problem and it fired up 8) 8) 8) 8)
only ran for a few secs as we had no water in :| but all in all a good day :mrgreen:
Postby 100 T280 » Sun Apr 20, 2008 7:54 pm
8) 8) 8) Cracking job!
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby Guy88 » Sun Apr 20, 2008 8:24 pm
nice one mate 8) 8) 8) 8) 8) 8)
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby mantav8 » Sun Apr 20, 2008 8:56 pm
Good on yer!-great feeling aint' it! :mrgreen:
mantav8
Cosworth Powered
Cosworth Powered
Postby Luke » Sun Apr 20, 2008 9:47 pm
mantav8 wrote:Good on yer!-great feeling aint' it! :mrgreen:
oh yes no matter how many times it always makes it worth wile :lol: worth being outside all day in the drizzle :x
jobs left before it can go to north weald :mrgreen:
buy radiator
sort out fuel pipes - at the moment they go round the front of the engine bay
pipe up radiator
refit propshaft
fit intercooler - gonna use the standard cossy one temp untill a custom one is made 8)
accelerator cable - needs adapting so its transit pedal to cosworth
finish off wireng (needs a lot of tidying up)
have a new pas pump hose made up to fit cossy pas pump
adapt starter so its held by more than 1 bolt :lol:
get exhaust made - planning on a full stainless system 8)
refit front panels
also needs fan cowl - but that wont stop us getting it on the road
