Sorted. It's still like this some months later, needs some thicker wood putting in to better support the weight/gaffer tape
Brand new secondhand tyre blowout shocker. It went down rather quickly this one!
Doing the brakes, This side was soaked with fluid as the cylinders were fubar.
Looming MOT meant I thought I'd get back to that hole in the chassis rail I found whilst painting the underside.
Chop chop
Masking tape and grubby thumb tech
Transfer the tape to suitable thick shelving bracket
Cut
Needed a tickle with the grinder and then it slotted in. At this point I found the gas had run out on the mig
Off to 'frauds and back with tea and
Sparkey spark and zinc primer, zinc primer went inside the chassis rail whilst it was sliced open too.
Stone chip
Top coat
Wax oil stuff added through the hole in the back of the rail for good measure. Decided not to replicate the hole in this side as that seemed to be where the problem started, also can't be arsed to grind back the underside welding as it noisy and boring work at the best of times.
Gonna throw it in for an early MOT next month which it might even pass, we'll see.
