Puk, a troublesome fairy!
Re: Puk, a troublesome fairy!
Postby limitedblack » Sat Nov 02, 2013 3:06 pm
Try this
http://www.carburetion.com/Weber/adjust.htm
Backfire I would double check for air leaks and cam timing.
Happy Easter
limitedblack
Postby robbie.cee » Sat Nov 02, 2013 3:50 pm
back fire - essex did that when the timing was retarded....bring it here illl gun it up! :wink:
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby jonochap » Sat Nov 02, 2013 6:40 pm
I think i might well need that! Thanks ltdb, they all seem to say knock back and forwards 2.5 so have done that again. Still an @rse starting and stopping. Also found bolt missing under starter (fell off today) and lost a clip to the air filter! Grrr :)
Owner of not so troubled puk :)
jonochap
Postby limitedblack » Sat Nov 02, 2013 7:01 pm
I think every pinto owner had a glass jar full of odd bolts, nuts, and washers ;)
Happy Easter
limitedblack
Postby jonochap » Sat Nov 02, 2013 7:26 pm
Thanks, thats reassuring :) wonder if i can befriend old people who still have jar fulls! :)
jonochap
Postby Muttley » Sun Nov 03, 2013 1:09 am
Stop messing with the air bleed screw John, only adjust idle with the throttle stop screw, if u want it all spot on then come to Sutton and I will put it on the gas analyser for u :)
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby mealic » Sun Nov 03, 2013 1:12 am
jonochap wrote:Thanks, thats reassuring :) wonder if i can befriend old people who still have jar fulls! :)
Thought you already had Jono :lol: :lol:
`04 2.3 petrol/LPG
mealic
Postby jonochap » Sun Nov 03, 2013 2:10 am
I see what you all mean :) :)
jonochap
Postby jonochap » Sun Nov 03, 2013 1:38 pm
Right! Screwed in air valve...mucked around between timing and mix valve and hey guess what??? No more popping or backfire! But every metal holder i had holding the air filter down popped off on the maldon ring road! :) is that a worry ( they came off one at a time not all together) :)
jonochap
Postby jonochap » Sun Nov 03, 2013 6:25 pm
Dammit...just seen the replacement cost aggghhhh!!!
jonochap
Postby jonochap » Sun Nov 03, 2013 9:05 pm
Do i need to drain the oil to refit the fuel pump gasket?
jonochap
Postby Muttley » Sun Nov 03, 2013 9:06 pm
Stop fiddling, or else :wink: :lol:
Muttley
Postby madbri » Sun Nov 03, 2013 9:43 pm
Muttley wrote:keep fiddling with my bum, or else :wink: :lol:
:shock: :shock: :shock: :shock: :lol:
madbri
Postby Muttley » Sun Nov 03, 2013 11:56 pm
Not bloody bums again :roll:
Muttley
Postby jonochap » Mon Nov 04, 2013 1:08 am
Tee hee :) i get the hint...
jonochap
