Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby robbie.cee » Thu Apr 04, 2013 12:39 am
Well happy...
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Thu Apr 04, 2013 12:41 am
My new dvr thingy has come already from China .well yesterday but missed post...
All set up and I can even view cams now on my phone in real time
Took ages to set up router but all done off to bed to dream of new house and triple garage! And pergola and stuff LOL
Had
MAKE IT FIT
robbie.cee
Postby RonTransitmk5 » Thu Apr 04, 2013 8:26 pm
robbie.cee wrote:Game on we are moving!
Offer accepted and ball rolling for mortgage guess we will know more in few days
At least now we know the house is ours tho.... Am elated !
WAHOO HAPPY DAYS
Well done bet your all :D :D
2003 Ford Transit Connect 1.8 TDDI Red.
1999 V reg MK5 Bus(M2) Mid Roof, 2.5di, diamond white. GONE
RonTransitmk5
Postby robbie.cee » Thu Apr 04, 2013 9:39 pm
yeah m8 dead chuffed! been a real novelty playing with the camera thing on my phone at work today too 8) 8)
next few weeks should be interesting, all waiting game now til all goes mad and we have to shift ! :P
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Fri Apr 05, 2013 9:59 pm
At last, weekend off and now im itching to play, gonna get the bulkhead moved,cut,hinged and re fixed in rear 3rd of van.
cut ply board to expose window orifice and seat belt mounting points...
if i get that done theres the central locking solenoid and delock too and the contact plates for the central locking on sld!
8) 8)
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sat Apr 06, 2013 9:32 pm
Game on sun was out got loads done today...
bulkhead in original position
ill have to retrim the rear of the front seats now, lucky i got left over seat covers!
plenty of legroom in the rear... well will be once tidied!
bulkhead in place after gettin cut, hinged but not yet affixed to floor or walls...
few shots from different places in van
took door card off the sld, disabled the slamlock, will at some point delock and weld hole over...
not so interesting piccy of a lock. solenoid will go in tomo when i remember where i put it!!
just need to find some suitable L brackets to screw up along sides of bulkhead to affix to van walls. will put brackets on both front and rear sides of bulkhead to resist it moving from stuff moving about or vandals.
the top bit as its hinged needs some kind of batoning so it forms a stop when up but allows flap to be hinged if i gotta shift a sheet of wood or a matress for example... :D
also exposed top n/s seat belt mounting point for the shoulder brace, roller mount point already exposed. will expose o/s point tomo!!!
am absolutely fkd/broken/aching so must have been a good graft!! :D
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun Apr 07, 2013 4:41 pm
Got a fair bit more done today . worked from bout half 10 til bout 3pm.
managed to find some brackets to secure the bulkhead to the walls. only small but will do for the moment til i figure out what will be more secure- dont want stuff flying through onto passengers. also need to get some lock/bolts to secure the hinged flap at each side.
the solenoid went in easier than anticipated... after cutting slamlock linkage out i only needed to drill 2 holes to secure solenoid to suitable place where it convieniently hooks onto the lock mechanism 8)
in place
securing screws
the next job was a pain, mainly due to owning shyte battery drill...
Sld contacts installed, made a bit of a hash of it but its in now so not bothered.
template stuck on and holes drilled...
wires connected and ran to footwell
solenoid locks and unlocks door- tested it by holding the wires i ran onto known live and earth. works really well considering!!
never managed to successfully locate 2 wires that reverse polarity coming from central locking... tried but got tired so im gonna cheat and fit a dash mounted switch that will lock and unlock- just a DPDT double pole double throw switch or even a mk3 window switch will do ... if i can be bothered ill look in haynes and see if i can find the right wires, doubt it tho think the solenoid im using is different set up to ford ones,despite in theory them just being electric motors!
now baby sitting a snoring little boy so finished for the day!
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Sun Apr 07, 2013 8:18 pm
Ive been using this site for years Rob http://www.the12volt.com/doorlocks/page3.asp#arp
I used 3 wire solenoids with reversing polarity relay setup on the van, along with a 2 wire motor on the rear door, all off one switch, might some other useful configurations on there too
Postby robbie.cee » Sun Apr 07, 2013 8:53 pm
cheers Al. i actually quite like the idea of being able to lock or unlock it from dash, easy to wire up a dpdt switch to do it... power goes to the middle two contacts (if its got 6 contacts) the end two pairs are joined on opposite sides forming an X and the take off to solenoid is from either end!! :D
did i imagine it Al , or do your window switches live in the centre dash area?
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Sun Apr 07, 2013 10:46 pm
Yes :lol: they poke out of the ashtray!!!! as I didnt know where I wanted the at the time (3 years ago), but they are going in the pod, hoping to get them wired this week...
Postby robbie.cee » Sun Apr 07, 2013 11:22 pm
anyone know what other cars i can rob switch from so it would either fit by heater controls or anywhere else that has a blanked off hole??
heard some escort switches were similar/same?? anyone? :D
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Sun Apr 07, 2013 11:36 pm
Wouldnt you want some sort of rocker switch, to lock and unlock
Postby robbie.cee » Mon Apr 08, 2013 11:07 am
AlanN wrote:Wouldnt you want some sort of rocker switch, to lock and unlock
yes but must be momentary like window switch thatt doesnt latch ijn either position!!! :D
Had
MAKE IT FIT
robbie.cee
Postby captain hook » Mon Apr 08, 2013 11:56 am
E30 Window switch :wink:
captain hook
Postby robbie.cee » Mon Apr 08, 2013 12:34 pm
What BMW e30? My beloved e30 ... Still miss it !
Good shout Cap'n
Had
MAKE IT FIT
robbie.cee
